Results 1 to 8 of 8
Thread: VX Commodore rough idle and accelaration after washing engine bay.
    VE Berlina
    Jan 2010
    Default VX Commodore rough idle and accelaration after washing engine bay.
    Hey Guys,
    I was my mums vx commodore yesterday including the engine bay. The car accelarates roughly and nearly stalls at times when stopping then accelarating. Can someone explain why this might be as the engine bay is dry?
    Has someone experienced the same problem after washing the engine bay and how was the problem fixed.
    Cheers.
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    well little more info how did u wash it? what did u wash it with.. did you make sure u coverd the important parts? also have u made sure that u didnt like feed the hose into the wires ect
    2000 VX Calais L67 !!!
    When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
    1DVSBSTD
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Although the engine appears dry water can get into a lot of places and remain wet for some time. Water can get into the rubber boots at the ends of the spark plug leads, into wiring connectors and other electrical components. It should eventually dry by itself but blow drying with compressed air or whacking a fan heater in the engine bay for a while will speed up the process. Check the plug leads for moisture.
    MY RIDE
    Jan 2008
    NSW
    check spark. with the car on take off one lead at a time from the coil pack. use tongs or something or you'll get shocked.
    VS l67 statesman
    Dec 2008
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Possibly a small crack in a coil pack has allowed water entry and fried it.
    Silver Certified.
    VE Berlina
    Jan 2010
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    SHould be fine mate, id say water just got into the lead boots or something, This is why i dont wash my engine down lol
  1. VT commodore rough idle and bad vibrations
    By vs2DSIRE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-11-2010, 07:20 PM
  2. vs commodore rough idle/vibration
    By IGNITIONSV6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2010, 08:16 PM
  3. VR Commodore rough idle
    By ragrim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2010, 08:35 PM
  4. VP Commodore rough idle when running LPG
    By Boofe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2009, 03:31 AM
  5. Rough Engine Idle
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2005, 03:47 PM
