Results 1 to 3 of 3
Thread: Rear Axle Issue
    vx lumina
    Mar 2010
    Default Rear Axle Issue
    Hi,
    I wanted to renew the oil since it looks like green sludge so referred to my manual which stated to remove the drain plug which has been unsuccessful because i can turn it left or right & either way just tightens back up?? I can only turn each direction about 1 full rev before it tightens up.
    So i proceeded to exact the sludge via a syringe and tube which was working ok until the plastic tube dropped inside and a part of me died.
    What are my options??
    Can i start the car and put it on ramps??
    I own a 01 VX Commodore V6.
    Thanks.
    VX acclaim S2
    Oct 2009
    Tighten it a turn n then loosen it another it should free up N probably has metallics in the thread, I wouldnt start the cAr.jack it up on then spot, worst comes to worse, take the whole back plate off
    vx lumina
    Mar 2010
    I finally got the drain plug off and oil has been drained but no sign of plastic tube
    I was using a spanner initially & ended up buying a socket from Bunnings.....
  1. axle tramp issue on vs 5.0l irs
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2009, 01:28 PM
  2. Axle tramp issue
    By 6 shooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 06:40 PM
  3. Using Harrop Adapter to fit VT-VY rear brakes to VL-VS solid rear axle
    By Surfwagon in forum Holden Commodore How-To's
    Last Post: 26-11-2007, 04:46 PM
  4. WTB lowered rear shocks suit solid rear axle
    By VS SII in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2006, 09:27 PM
