Results 1 to 5 of 5
Thread: How to change fuel pump in VT V6 sedan
    VT Executive V6 Sedan
    Apr 2011
    Default How to change fuel pump in VT V6 sedan
    Hi everyone,
    I got Holden Commodore VT V6 Sedan, this Easter I went to Beech Forest and as stopped at one point for taking pic, My car didn't started, it was making cranky noise and some time air filter was banging, one gentle man tried to help me out and he said might be my fuel pump is gone.
    Can any one help me how to replace fuel pump without taking out the fuel tank.
    regards
    Nadeem
    VT Acclaim Wagon
    Oct 2008
    Cannot be done but go here:
    Replacing Fuel Pump in VX Station Wagon
    Fairly comprehensive fuel tank removal directions without photos. Could be a good idea to change your fuel filter while you are in there.
    The job is much the same whether wagon or sedan.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Cant be done. Shouldnt take more than an hour to have the tank in and out anyway. They're easy as to do on the VT.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by nadeemrajabali View Post
    Hi everyone,
    regards
    Nadeem
    I wouldn't just go replacing the fuel pump because someone said it "might" be gone. Get it checked first and check fuse and relay. Get someone to turn the ignition on while you put your head near the fuel tank and see if you can hear a buzzing for a few second, if so the pump is working, if not, the pump could be gone. In quiet conditions you should be able to hear the buzzing when turning the key yourself. The pump will only buzz for a few seconds each time you turn the ignition on.
    MY RIDE
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Give your fuel tank a smack with a rubber mallet and see if it will start . This trick worked with mine for a while but it started to get noisy the crapped itself. The hardest part i found was draining the tank and disconecting the fuel lines with the special tool.
  1. how to change fuel pump on a vs
    By pervs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2011, 07:35 AM
  2. Can I fit a '95 VS V6 sedan fuel tank and pump/pick up to a '88 VN V6 sedan?
    By pjdm1980 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2011, 06:27 AM
  3. VY V6 Sedan, whats fuel pump like to change?
    By TheIceman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-12-2009, 08:29 AM
  4. How to Change Fuel Pump in VP?
    By surfrun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 08:03 PM
  5. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
