hey guys!! im hoping someone could help me
my car is making a squeeky noise. the sorta noise u would hear comming from a trailor attatched to a car. if u know what i mean. its very high pitch. (sorta like a bed squeeking!! )
the weird thing is it only happens after the engine is warm and when i do alot of corners it happens. the squeeky noise isnt constant. it happens louder over bumps or when im turning. but thennn when its idoling it happens softly after a hard run.
ive recently had the exaust done and ive tightened all the brackets and whatnot and the hinges look all okay!.. when i went to the mechanic he said it was the front sway bar link pin! but i didnt think it was because how come it happens when idoling? and i shook the hell out of it and the noise didnt happen. its defeniatly comming from the rear end of my car! any help is muchly appriciated!
thanks guys!
Try lowering your windows half way, that horrible window squeek sounds like it comes from different places and can drive you nuts
window door glass noisy squeek creak
Front window squeak
i've got the same issue but not as bad as you, only squeaks on small bumps in flat roads
i believe it's the rear shockers and it's brand specific
i'll try and have a look tomorrow chances are we have the same brand
yeah im assuming its that! but then why would it happen when its idoling and parked? its comming from the middle rear and under the car. im pretty sure its somewhere in the exaust brackets or what not
go out to the car and lift the rear wheel arch up and down either side of the car and tell me if it squeaks m8, i had a similar prob just last week after getting a toe kit put in..they used some new brand of grease which had melted coz the exhaust next to the bar and run out causing a noise like i was driving a friggin semi hahaha..give that a try![]()
Also check my ride,sitting on HSV R8 19's
" And on the Seventh day ,GOD created Commodores!!!! "
