Results 1 to 2 of 2
Thread: VT 5L temp high when idle
    VT Series 1 SS 5L Auto
    Oct 2009
    SA
    Default VT 5L temp high when idle
    can anyone help i was sitting in a drive through at maccas when my temp needle started to climb up, it normally doesnt go above halfway but now when its at idle it climbs up to 3/4 and the fans kick in. checked all my levels and they are fine.
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    Could be...
    Thermostat.
    Radiator Cap (bleeding presure into the overflow).
    A blockage somewhere in the radiator.
    I would flush the radiator / block, and change the thermostat and radiator cap and see if that fixes your problem before looking at much else. You can spend hundred chasing cooling problems (like I did), when in actual fact it's usually the $5 parts that fail and are the cause of the problem (mine turned out to be the water pump).
    Good Luck!
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
  1. vx ss temp creeping up at idle
    By wandoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2011, 09:50 PM
  2. Temp gauge reading to high.
    By 1998GTS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2010, 03:20 PM
  3. High temp readings
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2009, 11:21 AM
  4. VN 5.0 Temp at idle
    By Noy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 08:58 PM
  5. temp sensor voltage too high
    By vs-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2008, 03:30 PM
