Results 1 to 7 of 7
Thread: VT COMMODORE shaking.. annoying.. gearbox fluid.. FML
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    Angry VT COMMODORE shaking.. annoying.. gearbox fluid.. FML
    Hey guys.. i know i have problems left right n center.. but they all seem to get fixed by blokes on the fourm
    something that is really starting to annoy me.. is
    a.. the car when idling shakes annoyingly.. like something needs to be fixed..
    b.. i always seem to be toping up my tranny fluid.. with no noticable leaks..
    c.. i am starting to think my harmolic balancer is going.. and that could proberly be to do with part a..
    so what im asking is does anyone have any of these problems??
    will post up a video tommorw to make things sound clearer..
    just sick of these problems.. its only a work car.. and it shouldnt be this bad..
    it drives perfectly.. has perfect power..
    just sounds like old things are needing to be replaced at 300,005 kms..
    Cheers to anyone that helps
    2000 VX Calais L67 !!!
    When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
    1DVSBSTD
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    Quote Originally Posted by Cameron P View Post
    harmonic balances are common.. the rubber splits/cracks so check that
    cheers cam.. will have a look.... Would that make the whole car vibrate or would it be more gearbox/engine mounts related?
    1DVSBSTD
    VT Acclaim Wagon
    Oct 2008
    If the harmonic balancer is stuffed, it will be causing the cas to be sending incorrect signals to the ecu ergo, bad idle. Engine mounts will cause vibration if they are past their "use by" as they touch metal to metal. Combined with a crook idle you could get some very interesting results. Also, just some food for thought, if your transmission is on the way out that can cause similar symptoms when under load especially. This is from experience. A few months ago I had some bad vibration and noise sounding like tranny or diff. Replaced the tranny on suspicion, all good. smoth as silk.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by 1dvsbstd View Post
    one of my engine mounts is stuffed and it makes the car shake slightly but i never noticed till i jumped in another commodore, so not sure if yours is really noticeable or not.
    jump in your car put your handbrake on and put the car in drive.. accelerate a little to put the engine under load and get someone to check if the engine shakes/shudders or not
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    alright will do
    1DVSBSTD
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    Quote Originally Posted by graham7773 View Post
    hmmm really hoping its not.. but you might be on to something there.. will post a video tommorw
    1DVSBSTD
  1. VN-VS Gearbox Fluid and Filter Change (Auto)
    By Sean in forum Holden Commodore How-To's
    Last Post: 27-08-2011, 11:51 PM
  2. vs commodore help and info shaking/vibrating
    By jamiebrown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2011, 11:19 AM
  3. shaking manual gearbox between 2500 and 3500 rpm ??? any ideas ??
    By 94vrboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2010, 11:28 PM
  4. Gearbox Shaking?
    By xCalliba in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2008, 07:02 PM
  5. redline gearbox fluid..
    By nmj in forum General Discussion
    Last Post: 09-07-2006, 03:41 PM
