Results 1 to 23 of 23
Like Tree4Likes
  • 1 Post By and3rs
  • 1 Post By MR_VX
  • 1 Post By vx_commodore
  • 1 Post By drift-it
Thread: best power upgrade for ECOTEC V6 ($1000 worth)
    vx v6 comodore
    Jan 2011
    sunshine coast
    Question best power upgrade for ECOTEC V6 ($1000 worth)
    Hey again, Just wanting some ideas on what's the best engine mods to do to a stock VX Ecotec using around the $1000 mark....besides K&N panel filter and cold air intake, The Vt/Vx already has a CAI wich im sure would take plenty enough air for a stock engine. just really looking for the best bang for my $1000...thats all im really wanting to spend right at the moment... Also what power increase would i see?...
    going from a VP to a VX i really noticed the VX has less low/mid end power...alot smoother though..the engine has 100.000K.
    Thanx again
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    You'd definitely get the best bang from high ratio roller rockers... Check out mace engineering, they'll be able to sort you out ay mate!
    vx v6 comodore
    Jan 2011
    sunshine coast
    Thanx for the reply, I have been thinking about high ratio rockers but have heard u only get the benifit from 4000RPM+, I very rearly go near/over that, im just looking for better of the mark power and mid range power(Ecotec's are horrible for mid range power -i have found), Obvisley top end would be good to... what ratio is the BEST recomended for stock ecotec? without having to do the valve springs or anything like that?
    Thanx again...
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Plenum and manifold spacers will set u back about $370 that will help with the low/mid torque and a 69mm throttle body $220. All will help you out. Just send MACE a pm to help you out. If you get roller rockers go for 1.9:1's
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Either way, your still going to have a nugget 6...the little bolt on's help salvage a bit of a the torque...But your not going to see real results out of $1000 on a stock eco.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    I'd be looking at diff gears for better off the mark acceleration.
    If it isnt tuckin, it must be suckin
    VT Executive V6
    Dec 2006
    QLD
    If you want decent performance you bought the wrong car man, a vs with the ecotec feels so much more powerful than the vt/vx. I have both a vs wagon and a vt sedan both with extractors/exhaust and the vs feels like a totally different car, the torque of the ecotec is way better suited to the vs and no amount of money is worth spending to make a vt go slightly better, u should either sell it and buy a v8 version or some other car that is designed to perform. Probably not the answer u want but fact is u bought a family sedan at least they look nice though, spend money on extractors/exhaust and some fat rims
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    My VT wagon got chopped repeatedly by a VS wagon last night.... Even when I reacted quicker he caught me by the top of 1st gear My VX II would have smashed him though.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by and3rs View Post
    It would have more to do with power to weight ratio, the vs is heaps lighter then the vt. Its the same motor after all
    vx v6 comodore
    Jan 2011
    sunshine coast
    Sorry guys i should have explained my self a bit better at the start.
    Im not at all after a super quick cool look at my car its the fastest in town sort of deal,Coz i know thats not at all possible with the money i want to spend, All i was after is a BIT more power, As i said, I have found that the ECOTEC's are shocking as lowish/mid range power and im wanting to spend a little money on trying to resolve that problem, Im sure for $1000 there will be a good improvement from the standard power range, I just need to know whats the best way to go about it.
    Im really heading toward High Ratio Rockers, 1.9.1 OR 1.98.1,Wichever will be better?, I have a VY engine BTW. But maby there is a better option wich is the reason of asking the question. Obviosly the best power for the money is better. Exhaust is already done
    But again guys im not after a V8 supercar im just after a bit more power than the Vt/Vx have to offer (standard),For now anyway.
    Thanx again all for your help...
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    So if it's the killer lack of low-end torque you want to "sort of" fix, apparently Mace's manifold insulator and plenum spacer is said to solve this, relatively...
    After that go get roller rockers... Seeing as your engine is apprently out of a VY you'll only be able to get the 1.9:1 ratio rockers! I guess this a good thing seeing as you don't want to spend big dollars, cause anything higher than this ration you will need an aftermarket camshaft (as seen on mace's website) and when you start going down this path you'll need a tune to suit... Well and truly into 2g territory now haha
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    So what your wishlist should read (with the dollars that you want to spend):
    25mm manifold insulator - $220
    12mm plenum spacer - 150
    1.9:1 ratio roller rockers - $650
    TOTAL - $1020 (+ whatever postage comes to)
    P.s. I'd be careful with the plenum spacer as I have heard/read that it "can" make you loose some throttle response... Whether this is the truth or not i don't know cause I don't have it installed on my car
    vx v6 comodore
    Jan 2011
    sunshine coast
    brought a VX S x cop car, habib that owned it before me cooked the motor, so i got it and brought new heads and put them on and it went great, after that it started making a ticking/knocking noise so instead of chasing the problem i just pulled the old motor out and got a VY engine with 60.000K on it, but i pulled the old heads off the VY motor and put my recently brought new heads on it,(why not).. so anyway thats the story of why i have a VY motor..and yes it was out of a VY!...i know u were all dying to hear that!..
    I think im just going to go with 1.9.1 rockers, That seems to be the safe way of going about it, Then i wont have to worry about 'maby' having to get new pushrods/springs ect, also plenum + manafold spacers. Just hate waiting for shit to arrive in the mail, Very impatient.
    I would really like to buy a L67 and throw that in but i only just got this good cond VY engine.... and i really dont want to go thrugh the whole engine change over again by myself!!! Of corse all my mates were 'busy' that weekend
    Thanx again
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by vx_commodore View Post
    The best thing you can do is a good service and make sure your leads, plugs and injectors are in tip top shape. This is very basic but overlooked very often. Beyond that you don't have the budget to get even modest gains as IMO unless you go FI you are pissing in the wind with those things. All of the mods listed above are about removing restriction of air flow at high RPM. For your street car that spends most of it's life at relatively low RPM this is counter productive as it will actually slow air flow and kill low end torque. You may gain 5 extra top end kw which you might use once a week for a cost of 10% torque (or more) where you use the engine 99% of the time.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  15. #15
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    buy an l67, drive your N/a vx while you strip down and rebuild the l67 to handle 20psi
    jr689's wish list is where you should start and if that doesnt make you happy a diff swap to 3.4 or 3.7:1 might be what you want!
  16. #16
    vx v6 comodore
    Jan 2011
    sunshine coast
    yeh i definitly keep my engine in tip top shape, when i put the motor in i fully cleaned everything to do with the plenum/engine,Also got my mecanic to do a bit of porting while it was all apart, but other than that the oil is changed every 4000k(lil obsessive i know) plugs every 6000k, lead's,well i havent had to do them yet since i put new ones on with the new motor. I also keep up with a fully clean plenum by fully re cleaning it every service, Probably the cleanest engine around. I find it a good chill out sorta thing to just clean bits of the car.
    I know im not going to get a 10 sec car on a $1000 budget but just want that response back like my old VP.
    Thanx jr689 for that price list! definitly a good route to go for the $1000 mark, and im sure after thats done ill be happy with the results and thats all ill need to do.
  17. #17
    Reaper's Avatar
    Aug 2004
    The ecotecs were very doughy motors compared to the VP/VR motors. Not much you can do about that.
    Reaper
    Reapers Black VP SS
  18. #18
    VT Executive V6
    Dec 2006
    QLD
    Swapping to a higher diff ratio is the only thing I can see correcting the low torque issues. Look for 3.7 or 3.9 gears they will give a higher multiplication of torque and push rpm's up. You could probs do it for under 1000 too Also is it possible to put a tuned memcal in a vx ecu? I would recommend a tuned memcal to get more out of your exhaust. I want to get my memcal tuned too, it's supposed to be a pretty cheap mod
  19. #19
    Mar 2008
    If you're on a budget (much less then 1K) I would consider the manifold spacers first, in particular the a manifold insulator, which many reviews like the one shown in the link below from people who actually have our products. More so in your case given what characteristic you're after
    MACE Manifold Insulator & Plenum Spacer Review
    From there on end you could consider a set of 1.9:1 rockers which arguably, as the best value for money mod on these engines
    Though rockers help our mainly in the mid to top end range they also help out with part throttle drive ability which you'll positively notice under transient low RPM consider, plus the genuine power gains.
    Otherwise if you're you only want to focus on low range driveability, then a shorter diff ratio would also be something to consider.
    Quote Originally Posted by jr689 View Post
    Can even get the lower then that as well.
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  20. #20
    vx v6 comodore
    Jan 2011
    sunshine coast
    Thankyou very much for all the great feedback, I definitly have a good path to folow, This is my list:
    25mm Manafold Spacer - MACE
    12mm Plenum Spacer - MACE
    1.9.1? Rockers - MACE?
    Would 1.9.1 OR 1.98.1 Rockers be better for my needs??
    Because i have a VY motor will i need new pushrods? The heads i put on the motor were a RECO deal, So im not 100% sure what they were off originaly, I'd say VY because thats what i asked for,
    As far as im aware VX- you dont need new pushrods for rockers but VY - you do need new pushrods?
  21. #21
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    not sure on push rods with the vx as i only installed the 1.9:1 rockers and thats it. i hope it doesnt matter lol
  22. #22
    Mar 2008
    Given your requirements, I would stay with the 1.9’s
    If you have a VY motor you’ll need new pushrods, however chances are pretty good that you wouldn’t have been given VY heads, as they all “look” the same. So by chance you don’t have VY heads you’ll be fine without pushrods.
    Quote Originally Posted by MR_VX View Post
    Unless it’s ticking heaps, I wouldn’t worry about it Skinner pushrods are normally needed on only the VY’s. In saying this though we’ve come up with a way of running 1.98’s on VY, just need the time to document parts/processes etc
    MaceEngineering
  23. #23
    VT S pac S2 Manual
    May 2011
    newcaslte
    If it was me mate i would be saving another 4-500 and having an LSD center with 3.9 gear ratio heaps of low to mid power which what you want on the street.
  1. !!Ignition upgrade worth it???
    By slappedvr in forum V6 Development And Modification
    Last Post: 01-10-2009, 09:09 PM
  2. ecotec v6 VY power upgrade, what was it?
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 05:44 PM
  3. VT V6, Cam Upgrade... Worth it?
    By Riggy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2008, 05:01 PM
  4. 5L VN ignition upgrade can it be done is it worth it
    By Cossack1977 in forum V8 Development and Modification
    Last Post: 20-07-2006, 09:53 PM
