Results 1 to 5 of 5
Thread: Snapped idler pulley bolt
    99 3.8l VT COMMODORE
    Aug 2010
    Adelaide, SA
    Default Snapped idler pulley bolt
    Hi guys, im pretty new around here.
    I have a 99 VT
    I was doing my water pump yesterday and came to the bolt behind the lower idler pulley.. i started to undo and snap.. the pulley was still stuck on there (its off now, was seized on there) but now i need a new thing that pulley was connected to it.. What is it called ? ive read you can take it off from 3 bolts ? and how much would this part cost?
    'cheers i have a pic to show too..
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    You can buy the part, it's about $50 from memory. Just ask for the A/C Idler pulley hub.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VT Acclaim Wagon
    Oct 2008
    Or $10 from your local wrecker for a road tested part if you are broke like me. Are you sure you have enough Silastic in there?
    Aug 2010
    Adelaide, SA
    oh ok thanks umm have any of you got a diagram to show which bolts ?
    or easy to tell me to locate them ?
    cheers
    VT Acclaim Wagon
    Oct 2008
    Yours looks slightly different to my 1997-8 VT but if the bolts are the same, one on top, one on the passenger side and one at the bottom which also holds the harness retainer for the A/C. I just took one of these off my spare motor and two of them were nuts on studs.
  1. Idler Pulley Q
    By raovq in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2010, 06:06 PM
  2. Idler Pulley Bolt Loose
    By wicksey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2009, 04:05 PM
  3. Pulley idler changes?
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 06:52 PM
  4. vt Idler Pulley
    By sheapard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2007, 06:07 PM
  5. idler pulley arm
    By daron in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 10:48 PM
