Results 1 to 3 of 3
Thread: vu ute, some questions re lpg and uhf mounting
    vz tonner
    Aug 2010
    adelaide hills
    Default vu ute, some questions re lpg and uhf mounting
    alrighty ill get straight into it, i recently purchased a vu ute pics in the show off your ride section and now i have some questions.
    lpg:
    where can i mount the tank? i really dont want it in the tray or else with my tool box and swag etc there will be absolutely no room for anything else.
    performance? i used to have a vs and i occasionally had problems with back firing, wasnt really at any certain time either could be when taking off, cruising or slowing down. will i have the same problem with this? (3.8 ecotec engine)
    uhf:
    i have worked out where i want to mount it. now is the question of where to put the antenna.
    i dont want it out side bouncing around, the radio antenna is enough as it is. i was thinking of having a small antenna on a magnetic mount underneath the passenger seat for whilst im just driving and then if i wanted better range for road trips with mates or anything i could just wack it on the roof.
    will this work? i have heard that antennas dont work when they are touching anything, is this true? (it will just be a metal wire antenna at the moment)
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    UHF antenna's and range will depend on the type of antenna used, but rule of thumb is line of sight. If it is under your seat, it will have about the same range as a handheld = bugger all.
    There are new windscreen mount antennas out now that look the same as a phone aerial, my boss has one on his Sahara, range is pretty good and it's not obtrusive at all. They can be changed over as well as they have a threaded base.
    With the tank, you can put it under the rear but the spare will have to go in the tray.
    Visit my Facebook page
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I have a square transparent stick on antenna for my UHF - it lives on the back window, which isn't very good if you have tinted windows as the metal in the tint affects reception. Mine works great, and I don't look like a tool with a big aerial.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  1. Mounting a sub in a VU Ute
    By Rags1986 in forum Car Audio
    Last Post: 21-01-2010, 10:27 PM
  2. Mounting up the VR
    By acex1138 in forum Car Audio
    Last Post: 27-07-2009, 08:24 PM
  3. Replies: 0
    Last Post: 07-11-2007, 08:25 PM
  4. Mounting an amp in a Vs
    By RyVsAcclaim in forum Car Audio
    Last Post: 11-12-2006, 02:29 AM
  5. Amp Mounting
    By Spanner in forum Car Audio
    Last Post: 20-11-2004, 03:46 PM
