Results 1 to 8 of 8
Thread: Vt Calais heavy steering
    vr executive
    Jul 2009
    Question Vt Calais heavy steering
    Hi to all again best forum ever anyway over easter i stufffed my alternator so i got it replaced car sat idl for 3 day days with batt disconnect finally fixed all that next 2 days all was good and now my steering has got heavy when slowing going around corner or roundabout i do have a weeping power steering pump any ideas thanks
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Have you checked the fuse related to the power steering? It's the one marked "cruise control, power steering, mirrors". Try the mirrors, if they work the fuse is fine.
    MY RIDE
    VT V8 Calais
    Mar 2007
    You could be up for a steering switch, this is on the rack and allows extra power steering fluid to go through at low speeds which makes the steering easier.
    50LTRv8
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    There's a quick way to tell if the power steering is on the way out, does the power steering come back when you accelerate? Or is there a whine when accelerating and moving the wheel? Whack it in N and rev to 3000ish- hold it there- and turn the wheel a couple of times. If it's much easier and/or whining noise- it's likely it's the power steering pump in need of replacement.
    Could also be the fuse as accentstencil says, so check the fuse first.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Make sure your drive belt has been installed correctly and is not slipping.
    vr executive
    Jul 2009
    fuse ok going to replace the pump and see what happends from there if that fails reco steering rack thanks guys for all your help
    VT Calais
    Mar 2009
    SA - Victor Harbor
    my vt calais had a issue with its power steering, felt like armstrong steering for awhile, ended up being a faulty solenoid on the rack, was cheap and easy to fix, they have speed sensitive steering which sometimes stuffs up which is what my problem was
    VT Acclaim Wagon
    Oct 2008
    If it is none of the above, check your tyre pressures
  1. very heavy steering
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-02-2012, 12:01 PM
  2. Heavy steering in a VT
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2009, 06:21 PM
  3. Heavy steering
    By thehsvmanv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:06 PM
  4. Heavy Steering.
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2006, 04:35 PM
  5. Steering far too heavy in VT
    By Pezzer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2006, 10:04 AM
