Got some strip LEDs and putting them under the headlights, just need a hand splicing them into the Parkers, just wondering if I splice Into the plug that goes into the headlight or take the cap off the Parker and put it into them, can someone help me or guide me also could you tell me what colour wire from where. Thanks guys
hook them up to park lights. if you hook them into h/lights they will only come on when head lights are turned on...park light colour wire is black with white trace ...your leds are polarity sensitive (will only wire up one way)..should tell you on the carton some where which is + or -... + will be the black qith white trace...if you want to control them yourself ,you will have to hard wire them to a power supply through a switch...just keep in mind that you may have to rate the park light fuse up a little in amperage
They are black with white trace and just do it off the plug that goes into the head light?
??? Bump? Attempting tonightb
No reply n no one can help?
