Results 1 to 7 of 7
Thread: Vt-vx interior dash upgrade
    Vs excuetive
    Jan 2011
    Default Vt-vx interior dash upgrade
    I was just wondering if anybody has come across a thread on a how-to remove vt dash and replace it with a vy dash? Is it possible?
    Thanks. Matt
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    hi matt how are you..
    now in this world anything is possible.. there are a few people that HAVE indeed done it
    but you have to realise two things.. you need to RE WIRE alot.. eg for your dash and other things to work..
    Also it is going to look sort of out of place..
    its something i would do.. But it will take you a very long time..
    removing a vt dash is easy you just need to know how..
    cheers
    2000 VX Calais L67 !!!
    When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
    1DVSBSTD
    Vs excuetive
    Jan 2011
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by mwhit43 View Post
    Is there a thread that shows how to remove it?
    There probably is but finding it might be difficult, but try searching anyway.
    A Gregory's repair manual will explain the procedure, it will cost you around $40 and come in handy for other repairs.
    MY RIDE
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I've heard this takes some effort. Isn't it true the wires are double the amount on the vy than the vt vx ?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    ok,simple enough if you have time & more time. the vt-vz are basically the same car so everything generally bolts in the same.
    the easiest solution is buy a completely wrecked vy-vz then pull everything out it & transfer it into your car. use the wiring,the ignition switch,ecu,bcm etc-everything. that way less headaches. by using a complete wreck you will get all the extras you find you will need like shifter assembly,centre console,plastic bits bolts screw etc. then when your done just sell whats left
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    t1mm3hh's Avatar
    t1mm3hh is offline VX S PAC
    2001 VX Commodore S PAC
    Apr 2011
    Caloundra
    How to remove parts of dash
    the second post shows you all you need to know with all the tricky spots, other than the screws, you just need to pull it off with a tiny bit of force. be careful not to lose any of the clips as they are just sitting on little knobs in the dash. hope this helps
  1. Vp Dash Upgrade to Level 3 Vs Dash
    By Loud N Proud in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2011, 07:06 PM
  2. vs interior change please help/ upgrade/ buying new interior.
    By jadder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2010, 03:45 PM
  3. interior upgrade
    By PTRSEN in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2010, 07:15 PM
  4. VN, Interior upgrade :):):)
    By mitchy_vn in forum VN - VP - VG - VQ
    Last Post: 29-06-2010, 05:13 PM
  5. Interior Upgrade ?
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2007, 10:37 AM
