Results 1 to 3 of 3
Thread: oil pressure sensor
    VX Executive
    Feb 2008
    Default oil pressure sensor
    I got the 'check engine oil' warning light after changing the engine oil this afternoon. My mechanic said the oil pump was fully operational, there was sufficient oil etc. however, when we looked at this oil pressure sensor...unplugged it with the engine off and there was some water droplets coming out of the sensor and the switch.
    he guessed that the sensor switch short circuited due to this water. When i switch on the car, theres a beep-beep-boop-boop warning sound and the engine oil light comes on again.
    He said that i needed to dry out this switch harness and the oil pressure sensor, and better leave the car battery disconnected. now the car is in the garage and i'm waiting
    Worse case scenario, it might lead to other problems (?) , but i'm hopping the switch harness and the oil pressure sensor will dry out. Has anyone had this problem before?
    VX Executive
    Feb 2008
    plugged in the already dry harness into the oil pressor sensor. Reconnected the battery. Reprogram the CD player etc.
    And right after start up, the engine oil light warning came up again. Leaving the oil pressure to dry on its own didnt do anything.
    Has anyone experienced this?
    VX Executive S2
    May 2006
    Frankston South Vic
    replace the sensor very common problem, I have been told can cause engine to stall but have never heard of it for fact
  1. '99 VT Oil Pressure Sensor
    By CommieKal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 06:54 PM
  2. oil pressure sensor
    By shane100 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-03-2009, 06:25 PM
  3. oil pressure sensor
    By Deathadder in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-08-2008, 08:59 PM
  4. vy oil pressure sensor
    By Deathadder in forum Electrical Wiring / Questions
    Last Post: 09-08-2008, 07:39 PM
  5. Oil pressure sensor
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 11:48 PM
