Results 1 to 12 of 12
Thread: vt start then stop / immobiliser issue? dead key? PLEASE HELP
    vt
    May 2011
    goldcoast
    Question vt start then stop / immobiliser issue? dead key? PLEASE HELP
    hi all
    ive read alot about this on as many forums as i can and ive tried it all so please i need some real help.
    this is what happened
    drove to the pub, locked the car. came out and key remote (3 button) does not open doors, so opened manually. turn ignition, car turns over and fires instantly for a second then dies. huh? tried again same thing!
    (side note: a couple of weeks ago i turned the key and nothing....banged on the fuse box and tried again and it went)????
    right now if i turn the key slowely auxillaries come on and if i turn further to crank the starter, the radio lights go off as usual but no cranking, if i turn key all the way off and then quickly turn the key all the way to crank it cranks and runs for a second then dies.
    immobiliser light is always blinking
    i got the bcm numbers from holden
    got a new key programmed (locksmith looked at my old key and said the codes were still in it so i didnt need to get info from holden-even tho i had them, but he took codes anyway)
    new key acts just like the old one (yes i followed instructions to the letter for the new key)
    so i then sat in the car for 1.5 hrs with key in ignition on auxillary hoping immobiliser would be overridden (so ive read approx 40-60 mins) light still blinks and car still acted as above.
    the car is still at the pub and i dont know what else to do.
    please all serious info will be appreciated
    thanks
    jamie
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Could potentially be a faulty BCM, mate. Do you have a friend with a car the same? Swap the ECU, BCM and keyheads to get your car home. It will need to be the same BCM and ECU part numbers to work with your car though.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The immobiliser is not turning off, the immobiliser is in the the BCM. You will need a new BCM, it happened to me once with the exact symptoms that you described. If you buy a used BCM you will need the key head (remote) that goes with it and then you will need to have the BCM linked to your ECU with a Tech 2, which means a trip to Holden, unless you know someone else with a Tech 2. The car won't start until you get them linked, it's a security thing, otherwise people could break in and plug in their own BCM and off they go. I would like to tell you a simple fix but there is none and unfortunatly it's going to be a little expensive especially with a brand new BCM.
    You could try disconnecting the battery for a while as this might reset the BCM and fix the problem, computers do strange things, but I wouldn't hold out too much hope.
    MY RIDE
    VX Executive S2
    May 2006
    Frankston South Vic
    tow the car to somewhere safe and then get a good auto elec to look at it, could be bcm or just a fuse or wiring
    vt
    May 2011
    goldcoast
    thankyou all, more $$$ to go. what would a new bcm, ecu and keys cost from wreckers be i wonder...ill have to ring around.
    much appreciated
    vt
    May 2011
    goldcoast
    $150 for bcm, ecu and key from commodore wreckers goldcoast, doable
    thanks all
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jamie123 View Post
    much appreciated
    Best to ring around as prices will vary a lot but you need the same level BCM that you already have, you could get a higher level which would enable you to add things in the future.
    As lout said, you might want to get an auto electrician to check it out before spending big money, although I am confident your BCM needs replacing.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    thanks all
    That sounds cheap enough providing the BCM is the right level and the ECU came out of the same type of vehicle, not a V8 if yours is a V6.
    MY RIDE
    vt
    May 2011
    goldcoast
    Talking
    Quote Originally Posted by Mick1988 View Post
    thanks alot mate, this worked. i got bcm and ecu and key from wrecker $150. started 1st pop. cheers
    vt
    May 2011
    goldcoast
    [QUOTE=accentstencil;1850949]The immobiliser is not turning off, the immobiliser is in the the BCM. You will need a new BCM, it happened to me once with the exact symptoms that you described.
    thanks yip it worked
    VT Commodore
    Jun 2011
    Sunny Coast
    Hello to all, I have been reading this post as i have the same problem, my BCM is a 686 Mid, I have a mate who has a ECU, BCM and Key Fob from a VT Calais and the BCM is a 685 High.
    Would that work all right in my VT? First time Poster,really enjoy the site very helpful........
    VT 2
    Nov 2008
    Depends. VR VS bcu are interchangeable. VT series 1 is not. VT2, VX is. VU VY is.
    Low spec BCM's will start HIGH spec cars, but you will lose the high spec functionality in the dash.
    High Spec BCM's will work fine in low spec cars.
  1. Overheating in stop start traffic only - VZ SV6
    By MissSV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-11-2010, 04:00 PM
  2. VS V8 BT1 Immobiliser Issue
    By stuntmanmike in forum Electrical Wiring / Questions
    Last Post: 25-08-2010, 07:30 PM
  3. vt wont start (immobiliser or starter motor) please help.
    By evilhighway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-08-2010, 08:55 AM
  4. Remote Start and Factory Immobiliser
    By PigPatrol in forum Electrical Wiring / Questions
    Last Post: 17-01-2010, 08:39 PM
  5. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
Tags for this Thread
