Hi all,
A few months ago I asked for help regards to my 2000 Senator havingcomputer problems, Errors included and not limited to ABS,Oil pressure and that the car wasn't running very well.. Suggestions put across were injector issues, spark plugs and coils ect and that some of you never found the problem. Just letting you all know thanks for your feed back it certainly helped and that the problem has been fixed. It was a fault with the ABS system which then in turn caused other systems to show a error but left no fault codes tricky to find.
Thanks once again.
