Hi guys I'm After a cluster for my vt berlina n I just wanna know If a Vx dash will go in? What's about berlina or Calais??
1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
VT and VX clusters are the same except the colour might be different, so they should fit no problem. Berlina, Calais and Statesman will all fit except the gear position lights might not work in a Berlina, I don't know if Berlinas have that feature.
They only thing is, if you get a cluster from a V8 and you have a V6 you will need to get it recalibrated to suit.
MY RIDE
