Results 1 to 15 of 15
Thread: Slight knocking noise when idling in drive?????
    Vx Wagon
    Jul 2010
    Question Slight knocking noise when idling in drive?????
    After a recent long trip ive now noticed a there is a knocking or tapping noise when im idling in drive (at stop lights or stopping) if i put it in to neutral it seems to go away. Ive taken the drive belt off and it still does it and also the engine cover. Any one know what this could be?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    check your engine oil??
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    Quote Originally Posted by Cameron P View Post
    whats your car revving at???? check oil spark and gearbox ..
    cheers
    2000 VX Calais L67 !!!
    When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
    1DVSBSTD
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    just stick your head under the bonnet with someone holding the brake on whilst its in drive and listen to where its coming from
    could possibly be an idler puller or tensioner..
    Vx Wagon
    Jul 2010
    definately not the oil. ive changed the spark plugs and the leads and had the transmission serviced last week if thats what u mean by gearbox? Also it wouldnt be an idler or tensioner pulley if it still does it with the drive belt off would it??
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    My wagon does the same thing, I reckon your engine mounts are sagging / cracked.
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    look at the harmonic balancer too. big-ass pulley right on the bottom. you can't see it's cracked until the engine is turned off. the rubber splits on the outside and metal fragments get sheared off...makes an almighty rattle noise...
    Vx Wagon
    Jul 2010
    Quote Originally Posted by Cúl-Báire View Post
    thats what im really hoping its not. expensive repair? dont think id tackle that myself
    Quote Originally Posted by ch1mp View Post
    had a look i didnt notice any cracks or wear.
    2x 97vts and 2000 wh
    Feb 2011
    i would say engine mount or gear box mount my vt has the same issue and its the rh engine mount is stuffed ill be fixing it myself as there not to hard to do and cost Ive seen them from $30 to $60
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    to check if its an engine mount, start your car, pop the hood. push the engine to the left ( not to hard out) if it still rattles then push it to the right. if the rattling stops then its an engine mount. if it continues to rattle then look at your balancer. and to check if its the balancer take your drive belt off, then shake the balancer and if its loose and makes the rattling noise then thats it.
    ive had both problems with my vt had to change balancer and engine mounts, and rattling sound was fixed.
    and for a mechanic to change your engine mounts, at work the last one i changed cost 100$.
    but mate i may be wrong with any advise here, and hope my tips can help you out.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    Vx Wagon
    Jul 2010
    cheers for that dan ill give it a shot in the morning and ill let u know how i go
    VT Berlina Wagon S1
    Oct 2008
    If the sound is anywhere near the firewall/dash area, it's likely the aircon plumbing. It goes through the firewall behind the glovebox area, have someone sit in the car (in drive) and put your hand on the pipe... if it kills the noise, you've found it.
    Vx Wagon
    Jul 2010
    Quote Originally Posted by azzaVT View Post
    I checked that out today and its all good. I gave the engine a bit of a push and held it there while the car was running and it stops the noise so im going to change the engine mounts its seems thats what it is
    Vx Wagon
    Jul 2010
  15. #15
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    its engine mounts. if you pushed it and the nosie stopped.
  1. vs idling in drive not right
    By vs2DSIRE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2010, 05:05 PM
  2. Knocking noise only at idle and in drive.
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2010, 12:37 PM
  3. Slight Knocking in steering
    By edals in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2010, 11:08 PM
  4. Slight clunk from drive train..
    By 96 Calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 08:13 PM
  5. Slight knocking sound in rear of wagon
    By georgehifi in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-02-2008, 07:16 PM
Tags for this Thread
