Results 1 to 4 of 4
Thread: replace gear indicator lights in centre console?
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    Default replace gear indicator lights in centre console?
    does the whole console have to be removed to replace the gear indicator lamp(lamps)in the console of a vt auto? if so how do i remove the spring loaded compartments at the front and rear without breaking them.
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    Console stays were it is u have to start by removing the screws under the front spring loaded compartment x2 they just behind the rubber pad.
    You then have to pull out the console piece sorrounding the t-bar its clipped in and is a tight fit i usually start at the back somewhere.
    Then put your finger under the piece that lights up and you will feel the wires for the globe at the most rear part of this section.
    It then pull/twists out and exposes your globe
    they are a simple wedge parker style globe.....
    Hope this helps..!
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    cheers,thanks for that.i had hoped not to have to remove the whole console
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    done (would you believe it had been blown for over a week but i was not looking forward to removing the console for 1 lousy globe) thanks again ,it was too simple
  1. How do i replace my indicator globe??
    By holdengirl17 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2010, 03:40 PM
  2. gear and centre console lighting??
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2008, 10:16 AM
  3. gear indicator light in VK console
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-11-2006, 07:30 PM
  4. Replace indicator stalk
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 12:40 PM
  5. Centre console lights
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2005, 03:12 PM
