Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By chevy_big_block_bro
Thread: vt ecotec twin throttle body problem
    vt v6 5 speed
    May 2011
    sunshine coast
    Default vt ecotec twin throttle body problem
    hey all
    i have a vt v6 5speed that i just put a twin throttle manifold on and now i am having some problems with it
    i just got the heads rebuilt and put it all back to together and started it up and it idled perfect couldn't ask for a better idle did that 2 or 3 times then i dicided to take it for a drive and well took it for a drive up the road and back put in the drive idle was still fine then went to reverse back into the shed to have a check over for oil and coolant leaks and yeah it started to idle about 2000+rpm and i have the diagnostics test and the only code that came up was code 15 with is engine coolant temperature signal high anyway fixed that problem and did the diagnostics test again and the only code that came up was code 12 with is just to say the pcm is working fine
    now i have diconnected thebattery a couple of times and started it again and itidles fine until it get to opperating temp then it idles high again
    i have replaced the idle control valve with a new one and the tps and got another maf the only other thing i was thinking it could be is the vss (vehcile speed signal) because it is the only thing in the book that says anything about 1400+ idle
    if anyone can help me that would be very great
    thanks
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Have you had it tuned? Twin throttle ecotecs will idle high every time without a tune.
    We just discussed this oh..... 5 topics down from this one?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    vt v6 5 speed
    May 2011
    sunshine coast
    no i havnt had it tuned yet
    when i first started it after doing the heads it was idling fine but now it has just jumped up to nearly 3000rpm every time i start it
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    you CANT install and run a bigger/ttb without it being reprogrammed by your tuner.
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    YES YOU CAN.......
    I did it years ago on my old VT and it ran fine for almost 3 years on a stock tune.
    You need to make sure that one TB is totally hooked up stock and the other is just a throttle blade with all lines blocked/welded up. Also make sure that the MAF is hooked up to both intakes with no leaks on the TB side.
    Take it from someone thats been there, done that.
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
  1. Twin Throttle Body Ecotec intake
    By vs commi in forum V6 Development And Modification
    Last Post: 18-09-2010, 02:34 PM
  2. Ecotec Twin throttle Body manifold
    By Pub247 in forum V6 Development And Modification
    Last Post: 15-03-2009, 02:35 PM
  3. Twin Throttle-body Ecotec V6
    By Troy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2005, 12:26 AM
  4. Twin Throttle Body's
    By dumpd6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2004, 11:50 PM
