Results 1 to 12 of 12
Thread: starter motor?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Default starter motor?
    my commodore and my mates R33 both have the same issue.. when you start the car, mainly when its cold, it makes a grinding noise from the gearbox. i thught it was my flywheel and bearing thats stuffed and he thought it was his starter motor which actually makes more sense
    any ideas?
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    does it make the grinding noise when you change gear? eg in drive?
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Starter motor might not be dis engaging properly
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by DanLucas View Post
    nah man its a manual.
    it only grinds when you first crank it. but yeah jonnoo i think your right and the noise is when the starter motor trys to disengage
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    It could also be bent or some teeth could be chipped off?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    who knows what is wrong with it but at least i know the starter motor is stuffed.. will replace it when i do my clutch in a month or so
    VT acclaim
    May 2011
    melbourne somewhere
    sounds like the the pinion gear on the starter is grinding on the flywheel when you start it. i know of a lot of old falcons that do this, and in 1 case the flexplate (flywheel for auto's) had to be replaced because it had almost no teeth. when you do your clutch, check the condition of the teeth on the flywheel as well. it might be a better option to replace the starter now incase you do more damage
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by philba View Post
    Don't post tired :P
    VT acclaim
    May 2011
    melbourne somewhere
    um...if you read it again, i already had it that way around. the falcon with the damaged flexplate was an auto and i was meaning the flexplate was the laymans terms for the flywheel in an auto
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    im replacing the flywheel as its a DMF and i have already machined it already
    alright relax fellas..
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    I had the same problem with mine after my box got rebuilt. Sounded shocking for a while
    (was worried it was flywheel/clutch because I had just spent $3,000 on the box and new HD clutch)
    but it came good, still got a little noise but nothing major, mechanic told me if it starts getting louder
    then I should just bite the bullet and get a new one.
    None of us are as cruel as All of us. - Anonymous
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    yeah luckily for you it came good :P
    but the weird thing is, i havent had issues with my starter.. except one time a few months ago where i got to work and then went to start it again and it wouldnt.. then i started it at lunch time with no hassle. other then that nothing. but this noise came out of no where
  1. vy v6 starter motor
    By myvyute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2011, 07:34 PM
  2. vs starter motor
    By cannibalrikman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2010, 10:25 PM
  3. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  4. starter motor
    By holden123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2009, 08:52 PM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
