Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By bricat
Thread: EPA on exhaust noise
    Sabby's Avatar
    Sabby is offline MSABBY
    VU SS FIFTY
    Sep 2006
    melbs
    Default EPA on exhaust noise
    got a letter today from the EPA stating that they want to do a noise test on my vu ss ute
    it currently has extractors, 2 cats, center muffler but no rear muffler.
    if i put on the rear muffler and spend 150 getting that done, will it be at regulation noise? whichi is around 90db?
    or what else to do?
    cheers
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Sabby View Post
    or what else to do?
    cheers
    Probably won't be under 90db even with the rear resi. Don't quote me on that though...
    Could try on of these?
    http://www.xforce.com.au/about-varex...ts-muffler.php
    vx executive
    Aug 2010
    perth
    i know dick smith sell the noise testers (WA), i dont know much about exsaust but give a noise tester a go..
    Sabby's Avatar
    VU SS FIFTY
    Sep 2006
    melbs
    yeah i might borrow one off a mate
    sucks but its my own fault
    or i can leave it at it is and risk a $597 - $1195 fine or worse still at court $7167
    Sabby's Avatar
    VU SS FIFTY
    Sep 2006
    melbs
    thats a good idea about the motorised exhaust but looks fair pricey.
    went to an exuast shop and they said i gotta get a stock system from the extractors put on, $150
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    if its only $150 then thats better off than spending wat the fines r worth lol. least after u pass u can wack the current exhaust back on and keep the stock 1 if u ever need it again.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Sabby's Avatar
    VU SS FIFTY
    Sep 2006
    melbs
    yeah thats the plan for now. then weld on the old muffler on the rear that i took of woops .
    i am curious to see how many dB it is now
    VQ Stato & Evo VII.
    May 2006
    Melbourne, North of.
    If you fail the test you don't get fined, you'll just be told to change it so that it passes. In saying that, each test costs you $40 so you might as well make it pass the first time.
    It would want to be a mighty big rear muffler that you put on. If the cats are high flow and the centre muffler a straight through type it still won't pass with the rear muffler.
    Best bet is to have a standard system (if you still have it) fabbed to fit the cats and then it'll be right. Otherwise, throw a big rear muffler on it and some restrictor plates up front for the test.
    Edit: What diameter is the exhaust?
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Just get it flanged at the cats and get the exahust place to make a custom bit that all bolts up to your stock system.
    Get them to flange current system too so you can bolt/unbolt either system with ease
    Will be a few bucks to get them to do it but much easier if this ever happens again.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Sabby's Avatar
    VU SS FIFTY
    Sep 2006
    melbs
    dual 2 1/2 inch all the way from the end of the extractors.
    ill take all this info to the exxhaust guy and see what he rekons and how much itl be roughly. sounds goood tho cheers guys
    a mate said put steel wool in the exhaust to dampen it, but personally i think it wont do much, is it true tho?
    i havent got the stock exhaust, but i do still have the rear muffler. the exhaust shop said even with that on it will still be over the limit. he
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    GM GEN3's Avatar
    GM GEN3 is offline GM GEN3
    legs ATM
    Sep 2008
    S.A
    There is heaps around you can get a Stock none for like 50 bucks mate just put it in want to buy thing some one will have one mate
    \ TUNED LEGS BY MYSELF LOL
  15. #15
    VQ Stato & Evo VII.
    May 2006
    Steel wool does work but unless you live only a short distance from the exhaust shop, it'll all be burnt up before you get there. Not a good look to have it blowing out the rear muffler when they're doing the test either.
    Just have a big offset rear muffler put on and put some restrictor plates in front of the cats (between extractor/cat flanges). These are just a thin piece of solid steel with a decen number of small (not tiny) holes drilled through it. Car won't have much go about it but they work well to dampen the sound.
  16. #16
    VT S2 Calais 5.7 A4
    Aug 2005
    Had 3" S/S X/force and Mrs got pinged and that was with varex in restricted mode. Had rear muffler made with pea shooter out the back and passed test. They also took a drawing of exhaust system to cover their bum should you decide to change it after the test. So unless you get it done properly you will get pinged again. Mrs got done near Glen Huntley pub corner apparantly a common place they set up because of trucks. cheers
  17. #17
    Sabby's Avatar
    VU SS FIFTY
    Sep 2006
    melbs
    had the test today
    passed max is 90db and i had 89db @ 4200revs
    had on extractors, high flow cats then stock exhaust alll the way with a 1 / 1/2 inch tip
    because of the extractors it puts it up a littke at high revs.
    now back to where i started
  18. #18
    wrx884's Avatar
    Mar 2006
    wow really? wat extractors r u running? thats interesting coz i got the same set up but with 2 1/2" exhaust into a twin 2 1/4 tip, sure urs is 1 1/2"? thats kinda small is that y ur is quieter?
  19. #19
    Sabby's Avatar
    VU SS FIFTY
    Sep 2006
    melbs
    X force stainless 4 into 1 extractors only had 1 pipe going out the rear muffler, only that was 1 1/2 inch, tiny. i dunno if it did actually make a difference. but most if not all v8's have 2 pipes going out the rear i think so yeah maybe 1 pipe could drop a few db's
    the usual system is xforce extractors high flow cats 2 center mufflers to a rear muffler, all dual 2 1/2 pipe with 2 3" dumps
  20. #20
    wrx884's Avatar
    Mar 2006
    ahh woops i didnt see u had an SS would b totally differnt 2 mine then haha
  1. Exhaust noise?
    By VK SL 3800 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-03-2010, 06:11 PM
  2. vz exhaust noise ?
    By simoo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-08-2009, 07:48 PM
  3. exhaust noise
    By Conn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2008, 10:34 AM
  4. exhaust noise
    By CM99VT in forum V6 Development And Modification
    Last Post: 08-02-2008, 03:56 PM
  5. Exhaust Noise
    By LisnM8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2008, 10:30 AM
