Results 1 to 18 of 18
Thread: winscreen washer problem
    VT II Executive Wagan
    Mar 2011
    Default winscreen washer problem
    ok it was fine b4 but now then i was the wash my winscreen water only come out from 1 of the 4 holes can this be the pump problem?
    D22 St-r Navara
    Dec 2010
    perth
    VT Calais
    Mar 2009
    SA - Victor Harbor
    best thing i find is take hose off, then use a aircompressor to blow it out, simple as
    Mar 2011
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    use a needle or a toothpick to pock the holes with to clear the blockage. Also check the rubber piping under the bonnet to make sure it's all connected correctly may have come loose.
    You can buy a can of air from auto stores if u wanna be lazy.
    Mar 2011
    repco dont have the one i need it =[ n yesh i check the pipping n yes it working fine n yes i poke the holes all 4 of it n still doesnt work =[
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    persevere with the fine needle,albeit with care,i'm sure you'll be successful.once you get them working you'll find that they've actually swivelled a bit while you've been poking around so you may have to stick the needle back in the holes and move it around a little to redirect the stream of water.double check your hoses though they can get pretty gunked up.
    Mar 2011
    ok will do is there any how to take out all the hoses for cleaning or replacement?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by hunterjerry View Post
    Just follow the hoses and unplug them. You can unclip the nozzle from inside the bonnet if you want to remove them. New nozzles are $20 a pair, I priced them the other day, a bit rich as usual.
    MY RIDE
    Mar 2011
    Quote Originally Posted by accentstencil View Post
    where did u priced from?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Paul Wakeling Holden, Campbelltown.
    MY RIDE
    Hot-Rod's Avatar
    Sep 2005
    Oz
    Does anyone know if you can get aftermarket ones that spray a horizontal spray as aposed to two streams from each windscreen washer nozzel?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    if its coming out of 1 hole in the jet and not both then it would definetely be the jet that needs replacing and not a blockage in the hose.
    so yeah if a needle doesnt work, just grab a new pair
    Mar 2011
    just got a new pair for just over 18 buck from waitara holden and they both work great so now im happy =D thanks guys
  15. #15
    VT Acclaim Wagon
    Oct 2008
    Probably a good idea to clean your washer bottle out and refill with proprietary windscreen washing solution. The commodore washer bottles are known for algae growing in them and blocking things up, especially the filter in the bottom which most owners do not know is there. Needs to be pulled out and cleaned occasionally. Or just let it go and block your new nozzles again.
  16. #16
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    CLR is great 4 these, just let them soak over night ina jar and they'll b like new again.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  17. #17
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I'd go the needle trick, then switch them on and keep poking needle in until all shit has come out, then use the needle to re-adjust the spray direction.
    I had a look in Autobarn recently for a washer nozzle set for something else I was building, but they didn't have a great range (one to choose from!) So if you are replacing them, go genuine.
  18. #18
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Good idea to use the correct detergent in the washer water to deter any algae from growing and blocking the nozzle jets. A good splash of metholated spirits in the water will also keep things clean.
  1. Windscreen washer problem
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2008, 06:36 PM
  2. washer
    By Pauly2478 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2006, 06:25 PM
  3. Winscreen wipers
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 09:21 PM
  4. New Front Winscreen
    By ashtray1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2006, 10:57 AM
  5. Question about the plastic grill at bottom of Front Winscreen
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2006, 05:38 PM
