Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By cander24
Thread: not showing 10 psi on gauge
    vt commodore
    Apr 2010
    Default not showing 10 psi on gauge
    hey guys, just fitted a xu6 chip to my 10 psi vt now it shows a max of 4/5 psi on the gauge any ideas ?????????
    NO RIDE AT THE MOMENT
    May 2011
    New South Wales
    vt commodore
    Apr 2010
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Is this an L67? Why do you call it a 10psi vt? Just because you've fitted a "10psi pulley" or were you actually seeing a 10psi gauge reading prior to the different tune? That tune shouldn't change this. Are you still using the boost control solenoid?
    VS Stato l67
    Mar 2009
    Melb
    What boost did it originally show? Delete the boost solenoid for a start as they are notorious for playing up. The XU6 chip shouldnt change the boost at all so thats a strange one...
    VT SS S2 A4
    Aug 2005
    vt commodore
    Apr 2010
    not shore about the boost solinoid as i didnt fit the gauge, it was showing 9/10 psi on full boost , where would i find the boost solinoid its got a auto gauge boost gauge on it .
    where should it be reading from .
    Aug 2008
    NSW South Coast
    You can take the boost/vacuum reading either off the boost tree on the passenger side of the blower or off the fitting already in the lower inlet manifold at the front of it. Standard it has a small black rubber cap over it to seal it. Boost control solenoid is located on the back of the passenger side cylinder head. These often fail and stop you seeing full boost.
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    vt commodore
    Apr 2010
    vt commodore
    Apr 2010
    yep the by pass worked a treat and o so easy to do thank you one and all
  1. VS fix for temperature gauge showing between 1/2 & 3/4 on idle
    By VS_Commodore_101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2009, 07:14 AM
  2. VT SS Series 1 fuel gauge showing up as empty.
    By MSE089 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2009, 02:20 AM
  3. ECU leds not showing up,what now?
    By leslloyd in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2008, 10:14 AM
  4. Auto Gauge 2"/52mm Smoke Series Boost Gauge w/ FREE gauge cup
    By pepstar87 in forum Parts And Other Items For Sale
    Last Post: 16-05-2008, 01:16 PM
  5. VN showing off
    By isaac_2jz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2005, 09:02 AM
