Results 1 to 9 of 9
Thread: Changing VT Thermostat...
    VT Commodore Wagon 50th Anniversary
    May 2010
    Melton, VIC
    Default Changing VT Thermostat...
    Hi Guys,
    I'm changing my thermostat tomorrow as the temp gauge has been all over the place and am hoping that this may fix the problem..
    Just need a bit of help...the gasket i got says that it is 'self adhesive', does that mean i don't need to use gasket sealant??
    Are they hard to change, anything I need to not do or anything!?
    Never done one before and don't really wanna stuff it up, I assume it's pretty easy to do, undoing some bolts, changing the over, re-doing bolts...easy as that??
    Any help appreciated!!
    Thanks
    VT Executive V6
    Dec 2006
    QLD
    It's easy enough, I did mine recently and didn't bother with gasket goo, just make sure you scrape all the old gasket off both surfaces, it shouldn't leak. Make sure you bleed the air out of the system after using the screw on the thermostat housing.
    May 2010
    Melton, VIC
    VS Executive series 2
    Nov 2010
    May 2010
    Melton, VIC
    thermostat housing off but the actual thermostat won't come out, it's not budging!!! Any ideas??
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    May 2010
    Melton, VIC
    all good, plyers did the trick! All back together now, hopefully it now fixes the overheating...the old thermostat had a boiling point of 106, isn't that a bit too high??
    vt s pack
    Oct 2010
    brisbane
    106 is when ur fans come on? saying you have a v6?
    91 is where the termo should up at
    May 2010
    Melton, VIC
    on the old thermostat it actually had 196 degrees, then i realised that's Fahrenheit, which is actually 91degrees.
    Anyway, changing it has fixed the issues so thank god for that!!
  1. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  2. Changing Thermostat 4.2L V8
    By ezkii in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2008, 12:56 PM
  3. thermostat
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2007, 06:31 PM
  4. changing thermostat
    By Coxy_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2006, 11:51 AM
  5. Excessive revs after changing thermostat
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 08:44 AM
