Results 1 to 13 of 13
Thread: 98 VT Wagon vibrations
    VT Berlina Wagon
    Dec 2009
    Default 98 VT Wagon vibrations
    Recently got back from a big roard trip and the car has been vibrating. First Noticed between 90km/hr to 110, pulled the drive shaft out and the uni joints ar solid and the middle bearing seems to roll alright. then driving around a bit more and the car seems to vibrate even when Idling.
    What area's would I want to look at?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    agree,engine & rear gearbox mounts.get lots of quotes though cos they will vary heaps.
    VT Berlina Wagon
    Dec 2009
    Thanks, got a drive from newy to port Maquarie today, so will be taking it steady. Might get them changed by a guy I know on the monday.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by bondy717 View Post
    Get them checked out before you replace them because without seeing the car my reply was only a suggestion of what the problem might be. It probably is a worn mount or two but then again it might not be.
    MY RIDE
    VT Berlina Wagon
    Dec 2009
    I had a look last night and there are small cracks around the engine mounts and the oil pan sits just below the cross frame. Is there anything else I might want to check, are there any tests i could do my self? I read one about jacking the engine a little to see how they look.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Jacking the engine up a little is the method I use. Put a thick piece of wood between the sump and jack and then jack it up about half and inch and then look at the mounts, any damage should be obvious.
    MY RIDE
    VX Commodore 2002 Executive v6. Ex Patrol Car
    Nov 2010
    Armidale, NSW
    VT Berlina Wagon
    Dec 2009
    I jacked the engine up a bit more than 1/2 an inch, the mounts seem to be solid (they are the black rubber ones) there was only surface cracks from the mud and crap on them, I reved the engine a bit and it rocks a little but only a few mm to a centermeter at most when reving, so the problem may lie with the engine it'self vibrating. I am thinking of looking at changing the ol plugs and leads to start with , one lead i noticed had cracking of the insulation near the plug tip connection when I was changing the exhaust extractor gaskt.
    VT Berlina Wagon
    Dec 2009
    Nah she just whinges when the car is not responding how she wants it to and if something breaks she recons it is because I touched it, then bawks at the cost of getting it fixed at mechanics. Oh she want s new car of course but forgets that a couple of hungy here and there is not as much as a car that is depreciating a couple of thousand a year. (Still will get a newish car in the next few years cause the creature comforts are worth it.)
    S13 Silvia, VR S2 Exec, VX equpe, VE omega
    Mar 2011
    If the engine mounts are ok, and they are not sagging (sump touching the crossmember) Check you the transmission mount. Sometimes they break and cause vibration too.
    VT Acclaim Wagon
    Oct 2008
    VT Berlina Wagon
    Dec 2009
    How would I go about checking that out? how much do they cost to replace? Oh and how hard would it be? Just a few Q's.
  1. bad vibrations
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2008, 02:56 PM
  2. Low Vibrations........
    By get1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2006, 09:00 PM
  3. vibrations
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2006, 01:50 PM
  4. VT Bad Vibrations
    By phild257 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2006, 04:46 PM
  5. VibrationS!!!
    By Bob129 in forum Car Audio
    Last Post: 29-01-2005, 09:42 PM
Tags for this Thread
