Results 1 to 3 of 3
Thread: Front left guard
    P-Plater VL
    May 2010
    Default Front left guard
    hey guys,
    ive already had a search for it, cant seem to find anything about changing the front left guard. i have a body kit on my berlina and i am unsure of the correct way to remove and replace the quarter panel.
    any links or hints would be greatly accepted
    cheers sam
    None
    Feb 2011
    Warrnambool
    I recently changed over my guard. You've gotta remove the side skirt, front bumper and bonnet. Also need to take off the gas strut that holds bonnet from the engine bay. The right size flat head will fit in the torque screws. Then just take off the bolts on the guard which are in engine bay, under the headlight, in between the door and car and where the side skirt meets the guard
    S13 Silvia, VR S2 Exec, VX equpe, VE omega
    Mar 2011
    3x 10mm bolts up the top under the bonnet. and two T30 or T40 torx bolts holding the gas strut on. I use a piece of wood on top of the motor and the other end resting on the bonnet to keep it up
    open the door and there will be 1 10mm bolt up the top
    Remove the guard liner and there will be 1 10mm bolt around the bottom half of the fender (near the drivers door) you will need an extension to reach this.
    Under the plastic side skirt, you can just remove half of it if you wish. There will be another 2 10mm bolts holding the fender on right down the bottom
    pop the bumper off which is easy, it just slides out of the plastic locators, and there will be 1 remaining 10mm bolt holding it on.
    then lift the guard off and disconnect the indicator light blub.
  1. VT front left guard
    By Anglosaxon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-04-2011, 10:29 PM
  2. [QLD] WTB VZ left hand front guard
    By gopher in forum Swap / Wanted to Buy / Trade
    Last Post: 22-04-2009, 09:07 PM
  3. [SA] VR/VS Left Hand Front Guard
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 11-12-2008, 08:51 PM
  4. [SA] [WTB] VT Left Front Guard
    By bpottz in forum Swap / Wanted to Buy / Trade
    Last Post: 09-12-2008, 11:00 PM
  5. Front left wheel flush with guard, front right within guard. What's goin on?
    By Evman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-02-2007, 12:22 PM
