Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By walesy
Thread: DIY shift kit ?????
    VX Lumina
    Nov 2010
    melbs
    Default DIY shift kit ?????
    I'm thinking about buying a stage 2 transgo shiftkit and a corvette servo for my vx, v6 and i was just wondering if anyone has tried it themselvs and if you found it hard to do.
    Also what is it like driving with a stage 2 shift kit installed.. if its going to drive like crap I probably wont do it
    BTW i have done several searches on shiftkits and none of them really answered my questions )
    Cheers.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    it wont drive like crap, dependent of what you call crap
    will just make your shifts firmer, as i understand it a corvette servo will be firm enough you wont need a shift kit
    If it isnt tuckin, it must be suckin
    VX Lumina
    Nov 2010
    melbs
    I like the idea of firmer shifts, its just that some people say that there 'neck snapping' :P
    But yeah might be a good idea to start of with a servo first, looks a hell of a lot easier to do aswell.
    04 vz clubsport, 6L M6
    Oct 2008
    radelaide
    lol, for them to be neck snapping i think you might need a bit more power than your ecotec has,,, however i understand exxageration plays a big role in decission making these days,
    go with the shift kit mate it'll be great, and the corvette servo will only help,,
    however i can't tell you if it's a DIY type of job or not
    04 z series clubby. 6 litre 6 speed manual
    Quote Originally Posted by Cúl-Báire View Post
    Stroke and Blow it for extra fun!..
    Quote Originally Posted by DM 55 WA
    thats only because instead of porn i look at pictures of your ute!
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    i thought DIY like as in make a shift kit, i made one for my old XR6 out of some resistors. not sure if you can do it for a commo though
    91 vn s
    Jun 2009
    Adelaide, SA
    Shiftkit firms/tightens up the shifts, ergo- youll know when it changes gears rather than the smooth slow gear change you have at the moment.
    It's probably not DIY, there is nothing from stopping you though. I think a stage 2 is jut some adjustments and new holes (and some other goodies) in the valve body, which is accessable without taking the trans out. its pretty precise and incredibly clean work though. Get anything in the valve body and your trans just wont function properly. A hair can make such a difference.
    A corvette servo u can put in yourself, its just a big bastard circlip and a seal to get the original one out, and reverse to put the 'vette servo in.
    Following the supplied instructions to a 'T' though.
    May be easier to get a trans place to do it for you. Trans work is precise work.
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    shitkits FTW :-D i wouldn't do it myself i got mine with the gearbox from craigs autos, the shifts are nice and firm! enough to spin my 20s when hitting second and chirping 3rd ... but that's with an ls1, not an ecotec
    Going where no late model stato/caprice has gone before.... GAME ON!!
    VX Lumina
    Nov 2010
    melbs
    I'm trying to harness as much of the stock power as i can cus its slow lol.....and i cant buy an V8 so ill give the shift kit ago , sounds like everyone loves them
    If i screw it up I have a spare gearbox lying around lol
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    if the gbox is outta the car should be a peace of piss tho in the car for a newb :O dunno
    vs commodore
    Oct 2009
    Tamworth NSW
    You can also get the auto trans shift times shortened and the shift firmness adjusted in the memcal settings..I have played around with the auto transmission part of the tune in my VS V6 and I have the trans shifting a hell of a lot better than how holden had it set,the auto trans even runs slightly cooler now too.Of course this is not going to compare to a full on shift kit,but it does speed up and firm up the shifts pretty good for the standard auto box,and it cost me nothing which is the best part....
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by Brett_jjj View Post
    Ive got an "XU6 chip" which is basically just the shift point sharpend up. Ive had several people ask if its shift kitted because of how firm it shifts and the way it kicks down a gear a bit more sharply. I would say it reduced Overall Commodore Auto Transmission Gayness Factor (OCATGF) by 10-15%
    walesy's Avatar
    Jun 2005
    Perth SOR
    yeah that does work but it still doesnt have the clamping pressure of a servo so it will proberly wear it out alot quicker
    VU S Ute
    Feb 2011
    I have stage 2 with billet servo and I chirp second wen hammering it. Car still remains drivable only prob I had was in the rain hammering onto the highway it chirped and I almost spun out. Lesson learned.
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    I have a corvette servo that i was going to install in my vt but never ended up doing if your interseted?
  15. #15
    vx v6 comodore
    Jan 2011
    sunshine coast
    I got a Transgo stage 2 shift kit + corvette servo in my VX v6, I was told by a few transmission places when i got mine put in to never put a corvette servo in WITHOUT doing it along with a shift kit. It apparently will wreck the gearbox quiet quickly, The shift kit makes the box alot stronger and be able to handle the corvette servo.
    I got transgo stage 2 shift kit + corvette servo installed for $370 about 3 months ago, not that expensive to get the 2 installed.
  16. #16
    VT
    Apr 2005
    QLD
    Installing a Corvette Servo into your 700R-4
    Shift kit does not physically make the box any stronger.
    Increases line pressure and enlarges fluid ports for faster, firmer shifts.
  17. #17
    VX Lumina
    Nov 2010
    melbs
    Alright, so does that mean the servo can wear out the Gbox even with a shift kit ?
    Definetly not a problem lol
    also does anyone know any good transmission mechanics in melbourne ill give them a call and get a price
  18. #18
    VT
    Apr 2005
    QLD
    Quote Originally Posted by liama View Post
    Servo is there to provide extra clamping force, it can only wear on the bore where it goes
  19. #19
    VX Lumina
    Nov 2010
    melbs
    sounds good, ill get a servo aswell :P
  1. HELP: Column shift to floor shift conversion?
    By FULLY 17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2012, 03:37 PM
  2. Performance Shift Module VS stage 2 shift kit
    By justbad4you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 01:19 AM
  3. shift kit and shift module?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 09:18 PM
  4. shift kit
    By head in forum Electrical Wiring / Questions
    Last Post: 15-02-2008, 09:49 PM
  5. anyone with shift kit
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2006, 01:23 PM
