Hey this is probly askd heaps but is 100kph at 2000rm pritty good? And also if i hold the revs at 3000-3500 rpm for a trip will this damage my engine at all? Cheers Dee Jay![]()
It will produce more heat since more frequent combustion would occur but as long as it doesnt overheat I cant see an issue aside from fuel use. Can I ask where you plan on doing this 175kph trip?
In a 5ltr 2000rpm at 100kph is the norm and work wonders for fuel consumption.
The same trip at 3000-3500RPM, will chew through fuel and you will find the engine will get extremely warm. Probably wont do your gearbox any good spinning at that speed for that long.
That said when engines are manufactured usually they are picked out at random and reved to max for hours at a time - this is done in controlled conditions though I wouldn't recommend it!
151 Countries, One Cúl-Báire!
Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
Cúl's AUII XR8 Ute!!!... Clicky Clicky!
im assuming its auto then yeah 2000rpm is normal for standard diff gears, manual will usually be a bit lower
Going where no late model stato/caprice has gone before.... GAME ON!!
I am curious, what gear would you be using for the trip to maintain 3000/3500rpm? And why? Assuming you are not going to be travelling at 175kph.
Oh and it is a manual so it that a bit high? Oh will the engine just warm up its got the trip comp in it and it says then engines sits at 87-93°c even when i was doing 3000 revs it was using shit all pertol it was only when i slowd down to 100 it chewed it all.. Haha and will it just wear the gear box down a little bit? Because i had a wrx and it sat at 3000 revs at 100 so yea and they said that was normal -.-
5th haha idk just let my car have a gud runnope not at all..
haha
yeh mine sits pretty standard at 1900 at 100kmh, but as the others said mate apart from heat shouldnt cause much drama!
nice bit of poke when u put ur foot down in 5th i'm betting!
Yea tru that! Ohh sweet so its not that bad then cheers for that
ahhh sorry my bad when i was thinking manual i had an ls1 6 speed in mind
Yea i got the aussie v8 hahamine was cheap so thats y i got it haha
