Results 1 to 8 of 8
Thread: how to change wheel bearings
    VT EXECUITIVE 1999
    Apr 2010
    Default how to change wheel bearings
    hi can anyone tell me how i can change my wheel bearings in my vt.... can i do it myself or should i get someone else to do it...... i am pretty good with tools just dont know how hard it will be.........
    thanks guys...
    VS Stato l67
    Mar 2009
    Melb
    Do it yourself. A gregorys service manual will be the best $40 you ever spent. It will pay itself off many times over
    VT
    Apr 2005
    QLD
    Raise Car
    Remove wheel
    Remove caliper
    Remove disc
    Unbolt bearing unit cap screws
    Clean
    Bolt on new bearing unit
    Buy them from Autobarn and the like.
    Recommended to get new bolts from Holden too
    VT acclaim
    May 2011
    melbourne somewhere
    Quote Originally Posted by VT-565 View Post
    Raise Car
    Remove wheel
    Remove caliper
    Remove disc
    Clean
    what about greasing the new wheel bearings?
    vs commodore
    Oct 2009
    Tamworth NSW
    The front wheel bearings are located inside a sealed hub unit and once the bearings are stuffed,you have to buy a complete new hub assembly as the bearings arent replaceable..I paid $180 each for my VS ones from the local holden dealer,some places wanted $480 each!!!..There are supposed to be cheap "chinese made" hubs getting around,stay away from these as they fail quickly and dont comply with our ADR's..
    vt s2 sedan
    Apr 2011
    brisbane
    and don't for get there are abs wheel bearings and no abs wheel bearings !!!
    Dec 2009
    Also if your using the same disc rotors make sure the inside surface that contacts the hub is free from any rust and dirt that could cause them to sit on the hub incorrectly as it will cause brake shudder.
    there are several international standards bearings the actual bearing would probably be of a standard dimension and as long as the manufacturer complies and is quality assured they should be OK.
    VT Acclaim Wagon
    Oct 2008
    ebay has these from $85 per side to ...... $120 per side, VT VX front wheel bearings | eBay
    sellers state made to Australian specs with 12 month 20000k warranty
  1. can you change bearings in idler pulleys
    By matty_r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2011, 08:44 PM
  2. wheel bearings
    By XRUFFX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2008, 11:09 AM
  3. VS Wheel Bearings & Axle Bearings
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 07:41 PM
  4. wheel bearings
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 12:13 PM
  5. How long to change rear wheel axle bearings
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 06:23 PM
