Results 1 to 19 of 19
Like Tree2Likes
  • 2 Post By Burnout124
Thread: VT Commodore self combustion?
    VT Berlina
    Oct 2010
    Default VT Commodore self combustion?
    Hi im the late owner of a vt commodore that decided to set itself on fire.. I hadnt drive the car for 6 hours leading up to the fire and was wondering why my car would have done that.. the most affected area was the front righthand side of the car.. i have a subwoofer installed but the cables for the sub were unaffected..
    here are some photos..
    VT Acclaim Wagon
    Oct 2008
    Sorry for your loss and probably stating the bleeding obvious but looks for sure like an electrical fire. Damaged wiring in that area. I would have thought fuses would prevent it happening but apparently not? Was the wiring for the sub fitted with a fuse? Is that it that I see coming off the battery terminal back past the cruise control? Anyway, my guess is wiring fault.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Holy crap mate!!! Does look like it was somehow a wiring fault, if that's all the wires fused together on the main body loom I can see there.
    There must have been a fuse that was way to big for a circuit fitted somewhere (or everywhere). That is brutal mate.
    Insurance?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VT Calais
    Mar 2009
    SA - Victor Harbor
    cant really tell where it started but in future put that the fuse closer to battery for that sub wire
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I agree with Burnout124 it is exactly what I spotted too, My dad's vt used to leak at the return line on the Fuel rail, Even after replacing everything, after couple months it'd start to drip. So I rekon it'd be something like that.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Possibly, but isn't that burnt wires there running along the firewall towards the drivers side?
    VT Berlina
    Oct 2010
    Quote Originally Posted by Burnout124 View Post
    posible leaking injector running down to the exhaust
    think that is a possibility because i had a crash a while back and i had a hissing sound coming from the front every time i accelerated.. i got it looked at but the problem was never fixed, cheers for the feedback.. still waiting on insurance to give me answers
    VT Berlina
    Oct 2010
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by jcuz View Post
    yeah thats all the burnt wires, the sub wire is intact underneath them
    yeah so I'd say major electrical fault, likely the wrong fuses were in. did you ever replace a fuse with the wrong one?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The fuel from a leaking injector cant really light up on the exhaust 6 hours after driving. After about 1 hour the exhaust is only warm. i would say electrical fault of some kind.
    VT Berlina
    Oct 2010
    i never touched the fusebox, and i had a service 8,000kms before this happened
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    that sucks major, how long have you had the car and what workshops have done work on it? it may not have been you but I reckon there was definitely the wrong sized fuse in somewhere. Any idiot can put the wrong fuse in, still turns the circuit on and it's all good until there's a short.
  15. #15
    VT Berlina
    Oct 2010
    had the car for just over a year now.. i heard back from AAMI and they cant tell how the fire started, they said it was too mangled.. they're only paying 4.5k so cya later VT.. got a monaro body kit sitting out the back waiting for it and a set of wheels waiting at the shop, what luck.
  16. #16
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
    If it had started in the wiring on the drivers side, why would the engine cover over the throttle body
    be so badly melted and not on the drivers side ??
  17. #17
    VT Executive
    Apr 2010
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Pretty sure thats a Berlina too.... What a shame. Nobody would buy that and put the time in to rewiring it and getting it going again it will be a parts car for sure.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  19. #19
    VHSLE/VXSS/VXEXEC
    May 2011
    sorry for you loss there mate...that sucks...i know that in a fire where the flames were at its intensity this is probably where the fire started as it has been burning the longest. looking at your car id say its the drivers side around the fuse relay near the strut tower if you look at your outside guard and bonnet you can clearly see where the heat was at its intensity the other side of the car has just melted because of the heat and the flames coming off underneath your bonnet...looking at your sub wire where you have the fuse it could of had a small nick in it exposing some wire shorting it out... as it looks like the wire is completely exposed meaning the insulator was completely burnt off behind the fuse like the exposed wiring on the firewall but who knows im guessing i know a lil bit about that sort of stuff but im not an fire investigator...anyway its bad luck mate i hope in the end it all works out for you.
    the good thing about getting older....more toysthe bad news more headaches
  1. Myt combustion engine
    By Red Ranger in forum The Pub
    Last Post: 18-09-2010, 11:59 AM
  2. [VIC] FE2 Suspension setup for VE commodore @ Ultra low King Springs for VE commodore
    By IGNITIONSV6 in forum Parts And Other Items For Sale
    Last Post: 05-09-2010, 02:39 PM
  3. 304 Polishing combustion chamber How?
    By VrWagz1 in forum V8 Development and Modification
    Last Post: 20-08-2009, 04:48 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
