Results 1 to 15 of 15
Thread: vx flat spots
    vx executive
    Aug 2010
    perth
    Default vx flat spots
    I have a 2001 vx which seems too hit a flat spot when speeding up, but only when on the freeway.
    i have had the radiator, tranny fluid and oil recently replaced..
    VX Berlina LS1
    Feb 2009
    Shepparton
    Just a suggestion, but it might be worth getting a spray can of carbon throttle body cleaner, could be a bit of carbon built up around the throttle body
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    pommyVL's Avatar
    pommyVL is offline PommyVL
    VX 5.7 SS
    May 2010
    Newy NSW
    my mate had this also on a 2005 VZ calais auto doing around 80km, then putting foot down it would feel like a slight loss of power and then perk up again. Also doing it going up hills too... he had it looked at, got computer remapped and it still happened, not sure what the outcome was. if i find out ill post.
    Just letting you know so that your not just looking around at VX problems
    mates in England driving 1.0L ricers
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    transmission? does it kick back a gear straight away? or does it hesitate?
    or are you only accelerating a little bit and the gear your in just goes no where?!
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    spark plugs/ leads might need replacing
    clean your maf/throttle body/injectors
    O2 sensor might need replacing
    vx executive
    Aug 2010
    perth
    ok will give the spark plugs and leads a go, and also purchased some injector cleaner,, hopefully it will hep it stop lag when i speed up, but only on the freeway. could i be fuel filter aswell?
    thanks for the help
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VS Stato l67
    Mar 2009
    Melb
    Are you refering to torque converter lock up or is there some other issue? What gear/speed/RPM does this happen at? and does it happen accelerating from rest or when your coasting from 80-100ks and try to accelerate from there?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    b4 u go replacing leads check the resistance on them 1st and see wat u get?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    vx executive
    Aug 2010
    perth
    umm happens as 90-100 kms. when driving around it never happens, and from standing start it is quick to shift with no lag. there is no sound when it does this, just 3 jolts then it goes.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    so the gearbox isnt shifting when you put your shift down? or it does but it just goes no where?
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by vxcommie View Post
    If its the 3 jolts feeling im thinking of, its a missfire and new plugs and leads should fix it
  15. #15
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    dirty throttle body/injectors.
    If it isnt tuckin, it must be suckin
  1. vt calais 97 flat spots
    By cappo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2011, 09:01 PM
  2. vt calais 97 flat spots
    Last Post: 28-04-2011, 12:14 PM
  3. Flat spots!
    By glenny1988 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2010, 01:58 PM
  4. Replies: 5
    Last Post: 23-08-2008, 11:29 PM
  5. Urgent - Flat spots
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2007, 10:54 AM
