Results 1 to 4 of 4
Thread: Replacing Vt rear welsh plugs,help please
    Vt wagon
    May 2011
    Jilliby
    Question Replacing Vt rear welsh plugs,help please
    Hi there I have just purchased a vt V6 and it has a leaking rear welsh plug.can these be replaced without taking out engine.I have been told they can be replaced by cutting a hole in firewall.is this true if so what is the trick.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Where exactly is the coolant leaking from? At the rear of the block and dripping from the gearbox bellhousing? Its not that uncommon if this is the case. The rear crank seal on these motors is held by an alloy plate with a gasket which is also used to seal off coolant passages. With time the gasket deteriorates and the alloy plate corrodes and then naturally begins to leak coolant here. Off the top of my head the plate/seal/gasket and bolt kit is approx $150. Gearbox needs to be removed to replace it.
    Hope that helps,
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by firieguy View Post
    I have no idea, but cutting a hole in the firewall sounds pretty drastic and I would think that you would need to remove the dash and heater assembly to gain access to the firewall and have enough room to be able to remove and replace the welsh plug. I think a big hole would be required. I think it would be easier to remove the engine but like I said I don't know and perhaps it is possible.
    MY RIDE
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    You want to take probably most of the dash out...to cut a hole in the firewall...to replace a welsch plug.
    Your car i guess.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. VR V6 Welsh Plugs
    By HÝPÕ-5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2010, 10:25 PM
  2. what size welsh plugs?
    By Youngblood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2008, 10:47 AM
  3. welsh plugs
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2008, 12:14 PM
  4. welsh plugs
    By Wonderboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 12:33 AM
