Results 1 to 21 of 21
Thread: Ticking noise
    VT SS 5.0 Ltr manual & 96 WRX
    May 2011
    Aspley, Brisbane
    Default Ticking noise
    Hey guys this is proberly askd heaps but ive got a ticking noise from my engine, the guy at super cheap gave me 15-40 oil and i think its to low could any 1 suggest what oil i should get? Its a v8 as well so yea thanks
    304runner's Avatar
    304runner is online now ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by 304runner View Post
    Id say its a "lifter" if the issue still happens after its had oil....
    +1 to that. Mine's got a noisy lifter, usually a sign that the car has a) missed a service or 2 or b) has covered a large distances (i.e. mine)
    Then again, with the age these cars are getting too, it's not surprising that the lifters are getting a bit noisy even if the above is not applicable.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    i have the same problem with my VS but it seems to do it on and off could it just be a loose screw ??
    VX series 2 S-pack Auto 3.8
    Jul 2010
    my vx does it aswell somtimes when you start it if it is warm u can hear a ticking noise then after 5 or so seconds it disappears, idles smooth even with that ticking for 5 seconds.
    May 2011
    Aspley, Brisbane
    Wtf is a lifters?? Haha and its got all log books up to date tho, only done 164k kms.... And yea i havent put new oil in yet havent got round to it. Cheers every 1
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Well obvioulsy start with the oil.. And I couldnt be arsed explaining what a lifter is..lol. (google it) When I replaced my lifters I made a noob mistake and didnt check the cam lobes for damage.. As it turns out a lobe was damaged and now its eaten away at the lifter again.... So I need a new cam and lifters
    VT Acclaim Wagon
    Oct 2008
    May 2011
    Aspley, Brisbane
    Aww that sucks!!!! Kk ill google it ha
    VT Acclaim Wagon
    Oct 2008
    I put this on a while ago but if you really want to know what can cause ticking in the top of your engine, here is what GMH has to say.
    VALVE TRAIN
    A light tapping at one half engine speed, or any varying frequency, can
    indicate a valve train problem. These tapping noises increase with engine
    speed.
    Before attempting to judge valve train noises, thoroughly warm up engine.
    By doing this you will bring all engine components to a normal state of
    expansion. Also run the engine at various speeds and listen for engine
    noise with the hood closed while sitting in the drivers seat.
    If the valve mechanism is abnormally noisy, remove rocker arm covers and
    use a stethoscope to determine which valves or valve train parts are
    causing the noise.
    Valve train noises may be caused by one or more of the following:
    1. Broken or weak valve springs.
    2. Sticking or warped valves.
    3. Bent push rods.
    4. Dirty, stuck or worn valve lifters.
    5. Damaged or improperly machined camshaft lobes.
    6. Insufficient or poor oil supply to valve train (low oil pressure).
    7. Excessive valve stem to guide clearance.
    8. Worn valve guides.
    9. Worn push rods.
    10. Worn rocker arms.
    11. Broken rocker arm stud.
    12. Loose or worn rocker arm attachments.
    13. Missing or mis-positioned lifter guides.
    Enjoy
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Normal oil for a 5l V8 is 20W50 - Castrol Edge Sport 20W50 is a good oil at a reasonable price (even better on 20% off days at Repco, Supercheap etc.).
    VT Calais 5.7 ltr
    Mar 2011
    ^^^^^ what he said.I get my oil when 20% off days are advertised and it seems to work in with my 5000 k oil changes
    Helps a little when paying 70 odd dollars for castrol edge 10/60
    VT
    Feb 2010
    I will not use any Castrol oils, after seeing what it done to this engine.
    This car got regular services the whole engine and engine bay look new
    Inside rocker cover
    Stick with real oil 20-50 and leave the 15-40 for the rice burners
    VT Acclaim Wagon
    Oct 2008
  15. #15
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by graham7773 View Post
    Dragon, that engine looks like it has had several interior engine fires
    It looks like it spent 6 months parked in Shrek's swamp garage.
    It can't just be Castrol oil that did that, that engine has some serious other issues methinks.
  16. #16
    vg ute
    Jun 2010
    shepparton
    Iv used Castro.oil.for a long time that can't just be from the oil looks like hasn't been serviced for a long time I do mine max 10,000km in ky old v6 Vt my v8 5l Vt will get changed 5,000km I'm running a gtx 3 15/40. Also water has gotten into that motor to.
    That ticking noise is common to hear in the older 5l like vn to vp. I Havnt heard it in mine few. Far as I know normal.means cam.lopes are worn out. So.must people just leave it
  17. #17
    May 2011
    Aspley, Brisbane
  18. #18
    VX S series II
    Sep 2010
    Changed the oil in my vx today,Was well overdue for it.
    Had the ticking noise before the change,Took it for a run after the change and it runs pretty sweet now.
    No more ticking.
  19. #19
    Mar 2010
    Cockatoo Vic
    just changed the spark plugs in mine (don't know how old they are but they have been in there ever since i got it on 2010 lol) and the ticking has almost gone only a very slight tick and i changed the oil the other day after replacing the manifold gasket and that didn't change the sound
  20. #20
    VX equipt
    Jun 2011
    May 2011
    Aspley, Brisbane
    I use 20-50 castrol is that ok??
  1. VK Ticking Noise.
    By Pie-VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2011, 12:38 AM
  2. vt 5.0 V8 Ticking noise
    By jesse'sVT5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2010, 05:17 PM
  3. Ticking noise
    By Cameron P in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2010, 05:53 PM
  4. Ticking noise!
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 05:30 PM
  5. ticking noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 06:44 PM
