Results 1 to 13 of 13
Thread: vt suspected gearbox failure coming
    vr calais vt berlina
    Jul 2008
    Default vt suspected gearbox failure coming
    over the last three months my vt v6 has started droping down a gear after going up hills and not upshifting again until i turn off the car then it runs fine any ideas would be a great help im told it may be a shift solinoid
    som
    som is online now
    vt executive
    Apr 2011
    thorneside qld
    i may be talking crap but 50,000ks ago i was told by my mechanic and by an auto trans specialist that i needed a new tranny cos mine was behaving in a similar (but not exactly the same )manner. I read a jc thread that suggested it may be simply a tuning issue so i thought what the hell,has to be worth a try so i went to my local dealer and bought genuine plugs,leads and a coil pack and "voila",fixed and it's still running as good as new.my car has now travelled 360,000ks and as i said in the beginning the last 50,000 has been since i supposedly needed a new tranny.just a point.i read a comment by "not an abba fan"a day or so ago where he said that simply testing your leads for resistance isn't totally accurate.i'd be keen for you to get an opinion from him cos he seems to really know his commodores.
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by lestat2220 View Post
    Mine does the same thing, looses 4th, if you find out what has caused it, please let me know. Cause that is the very same problem mine has.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    they loose 4th due to excess heat. AKA slipping transmission. Id start with replacing the oil/filter in it. If its still dodgy possibly tighten the bands. or get a new one lol
    som
    som is online now
    vt executive
    Apr 2011
    thorneside qld
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    if you are doing mass hills and/or some towing id recommend getting a transcooler as well
    If it isnt tuckin, it must be suckin
    Jul 2008
    thanks guys i booked the car in for a gearbox service today will let you know if it fixes the problem
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    The band can be adjusted by using a longer apply pin, this is the only method.
    som
    som is online now
    vt executive
    Apr 2011
    thorneside qld
    i wonder if i'm the only dumbass that has believed his mechanic who's been servicing the auto trans in our 2 vt's for years (@ $185 a pop ) and has had me convinced that there were no adjustments possible. that's not to say that those of us who don't know what we're doing should suddenly begin playing around with with a band adjustment or that in most instances one is even necessary but it's still good to know.thanks mate.
    Jul 2008
    so i have spoken with the transmision specialist and he thinks im right its a solanoid problem tomorow hes going to test it and if it is he said im looking at $250 to fix including a service sound resonable to me
    Jul 2008
    well we done a diagnostic got dtc 87 wich mean could be ####ing anything internatly ####ing great help that was looks like im up for a rebuild guys
    Jul 2008
    ive found the problem 1 of the check balls was jammed in the valve body spacer plate so a replaced the plate put in a transgo stage 2 shift kit and now everything is running like a dream again hope this helps someone else out there
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    common problem with balls bashing out plate then getting jammed
  1. Whining noise coming from Auto Gearbox?
    By nitrowarrior in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2011, 02:44 PM
  2. Code 33: Suspected MAP sensor (2 Bar)
    By Shearer in forum Tuning
    Last Post: 20-01-2011, 01:10 AM
  3. Skaife's Replacement. (As Suspected)
    By NickVR in forum News/Updates
    Last Post: 28-01-2009, 05:51 PM
  4. Gearbox oil leak?? Where could it be coming from...
    By t3zza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2005, 08:06 PM
  5. VN T5 V6 BT1 .. gearbox failure, scrapping for parts
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2005, 10:53 PM
