Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Boonz
Thread: wh grange problems
    wh grange
    May 2011
    perth wa
    Default wh grange problems
    howdy my wh grange is going el loco dash warning lights. abs. airbag .check engine. oil light r coming on while im driving then they go away and come back has anyone else had this problem and do holden have 2 fix it?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    usually its the abs module, pop your bonnet and disconnect the connector on the ABS module itself and most of the lights will go away, (apart from the ABS ones) if that works, you need another abs module
    wh grange
    May 2011
    perth wa
    cheers mate will do after dinner and will repost after check
    wh grange
    May 2011
    perth wa
    Boonz's Avatar
    Jul 2005
    unplug it with the ignition off, then switch it on and see what dissapears
    scvs6's Avatar
    scvs6 is online now Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    That happened to my WH Statesman, was the ABS Module. $950 from Holden or $350 from Logicar.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    wh grange
    May 2011
    perth wa
    thanks for your help looks like it is the module hopefully i can find somewhere 2 get it in wa other than holden
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Tell me the part number on your module I might have a 2nd hand one to suit.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    none
    Apr 2010
    Place in Welshpool will do a swap for $320 got one done a month ago.
    Precision electrics, place is actually call AFI on the building (Briggs street)
    10 minute job just undo 6 torx screws pull the clips and remove black part from the silver block.
    There are only 2 types apparently depending on if you have Trac control or not (you do).
    HTH
    wh grange
    May 2011
    perth wa
    wh grange
    May 2011
    perth wa
    if i cant get 1 where this fella told me i will let u no 4 sure thanks mate
    2000 wh statesman gen3
    May 2011
    mildura
    on ebay,,,$160+$12 freight they reco and fix the problem,,type in abs all the models will be there,,cheers john
  1. VP v6 to v8 using vr grange
    By Matty-CVPSK8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2009, 03:34 PM
  2. How much for 5.7 hsv vs grange?
    By axemurderer101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2009, 04:35 PM
  3. Z Series R8 or WK Grange
    By Neat5L in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-05-2008, 01:39 AM
  4. 6.0 ltr Grange
    By VtBerlina_3800 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-03-2006, 01:41 PM
  5. Vz Grange!!!!!!!!!!
    By VtBerlina_3800 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2006, 12:28 PM
