Results 1 to 5 of 5
Thread: VT diffs and ABS
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default VT diffs and ABS
    The diff in my VT whines pretty bad. Can get a second hand one pretty cheap (single pegger, same as wats in it now), but I can get hold of a VP IRS LSD diff pretty cheap...only thing is it doesn't have ABS. Can I convert the VP diff to ABS? I dunno if it's something that can be changed over or whether it's a part of the actual housing.
    Anyoe know?
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i think the abs sensors are in a bolt-on bracket, and if your output flanges where the axles bolt on have teeth around the outside (for the sensors to read) it should work ok
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    DANNY8's Avatar
    Apr 2004
    The VP diff doesn't have the teeth on the output flanges (the car it come out of didn't have ABS), is there anyway to change that or would I just be better off finding a diff with ABS?
    ve sv6
    Aug 2010
    as dirt drifter said, your sensors bolt on and use your own output flanges of your drive shafts, and should be good.
    DANNY8's Avatar
    Apr 2004
    Was just reading one of the manuals I got and it says the following about removing the output flanges...
    CAUTION:
    If V6 engined vehicle is fitted with LSD, do not
    rotate the opposite axle shaft, as side gear and
    clutch cone splines will become misaligned.
    Then the axle shaft cannot be reinstalled
    without removing differential case, dismantling
    and realigning gear and cone splines.
    NOTE:
    The above ‘Caution’ does not apply to the V8 or V6
    supercharged engine final drives, because the side
    gear and LSD cone is an integrated component.
    My diff has been replaced before, and I assume it's a stock NA 6 open diff, so I guess the output flanges WON'T be interchangeable between my diff and the VP LSD diff.
    Might just be throwing another single pegger diff in there I rekon lol.
  1. VP Diffs ; what diffs will fit into a vp
    By manar0 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2010, 09:01 PM
  2. Diffs
    By holden08 in forum V8 Development and Modification
    Last Post: 20-03-2007, 11:44 AM
  3. vs diffs
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 06:45 PM
  4. Diffs
    By davebart25 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 02:55 PM
  5. Vl Diffs
    By VBSL79 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-02-2004, 08:50 PM
