Results 1 to 21 of 21
Thread: vt 99 flat battery problem everytime i drive with subs going
    Commodore
    May 2011
    Mandurah
    Default vt 99 flat battery problem everytime i drive with subs going
    I have a problem where everytime i drive for abit and pull up for anight or two my battery is dead flat , Im wondering if my sony 1200 watt subs and 700 amp is draining them ? can anyone help me with why this is happening or has it happended to you and what youv done to prevent it
    cheers damo
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    buy yourself a yellowtop deep cycle optima battery. I had to get one of these when i had big sound in my old vp commodore cost me 600 from century battery at kunda park sunshine coast solve all your problems
    VP Wagon
    Mar 2009
    compasitor for the sound system, or you could check to see if you alternator is doing its job (most likely the brushes)
    Commodore
    May 2011
    Mandurah
    just bought a new battery last week so up not really up to buying a new one just yet,
    cheers juice1929 how much is this capacitor going to cost me? and what chances of it could be the alternator ?
    2000 VX Acclaim
    Mar 2011
    I've read on here somewhere, that some amps, although installed correctly, they don't turn off when you turn the car off. Or, they may turn off initially, but when you lock your car, they power back up, there was a thread on here not along ago, should still be on the first page of the VT-VX section
    I take it when you say pull up for a night, your not playing music whilst the car is off, because then the answer is a bit more obvious haha :P
    Hope this helps
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Beno1982 View Post
    you got ripped off bigtime
    Power is measured in DECIBEL
    Commodore
    May 2011
    Mandurah
    okay thankyou heaps , and to anwser your question no i do not leave my music playing , iv bought a new battery aweek ago , new terminals , iv tryed everything there is to it , my only guess is that the amp is staying on wilst the car is off but i have no idea how to fix the problem if it is that?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    There will be some lights on the amp somewhere that will tell you if its on or not.
    If you want to check if its the amp, drive around playing music, then when you get home check the voltage of the battery, than pull the amp fuses, then in the morning check the voltage again. If there is any difference than its not the amp.
    Ronald Reagan (1986)
    Commodore
    May 2011
    Mandurah
    thanks heaps mate , should help me out a little though im not to sure if it has lighting on it , i will look tomororw night and get back to you . Might be a case of taking it to a auto electrician or audio shop ..
    VX Berlina
    Apr 2007
    Nah try pulling the fuses first, just remember to disconnect the battery before refitting them.
    Also just for the hell f it, check the voltage with the car on (but stereo off), and with the car off. Should be about 14.4v and about 12.4v
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    Quote Originally Posted by SweetWagon View Post
    I don't think i went to autobarn, repco and they were qouting me between 700 - 750 mind you this was also 5 year ago aswell i not sure what they worth now.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    um how bout finding out if ur alternator is keeping charge? ur regulator might b on its way out which is a common thing. as u havent got a massive system so a standard battery and standard alternator should run them fine.
    DONT use a capacitor big waste of time and money as they dont work unless ur pulling massive power and have well over 10 farads cap. Do the "Big 3" wiring up grade on ur ground and u should b fine.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VZ Lumina 4sp
    May 2011
    I had 2 kicker cvr's in my car once, 750.1 amp to match. I had the same problem that you do. Turns out the alternator had eaten itself.
    Your alternator might be on its way out, when mine had fully died, the car was running on the battery alone. Got kinda scary cause I'd be sitting at the light, and the revs would start bounceing, then it would die. A good test is to turn the indicator on, and see if the revs bounce.
    But this was in a completely different car, so i'm probably WAYY off
  15. #15
    VT Calais
    Mar 2009
    SA - Victor Harbor
    your stereo is pretty small so i would be looking into problems with your alternator, get a multi meter and stick it on the battery terminals with the car running, anywhere between 13.9 - 14.1 is good, any lower you could heading for some troubles, also whats the model of your amp
  16. #16
    Commodore
    May 2011
    Mandurah
    thanks for all the help , the amp is a sony explode , no lighting on it to tell me if things are staying on ect, but iv been told by alot of people run a re-lay audio shops do them , casuing the amp to disconnect after the car is off ? i did also the flicker test the car isnt boucing or high revs so i assume it isnt the altinatoir , running out of options and im hoping this ree-lay will help it alot
  17. #17
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Go to a battery shop they should have a tester that will determine whether or not the alternator is charging under load. The flicker test won't tell you much if anything. The battery shop might even be nice enough to do it for free.
  18. #18
    Commodore
    May 2011
    Mandurah
    cheers for that , i might go down and look into it tomorrow , know the pricing range an alternator could be ? vt commodore 99 series 2
  19. #19
    series 2 vt wagon
    May 2011
    newcastle
    had a similiar problem... easiest way i found to get around that is to do what we did and install a switch in between the bat and the amps, and make sure its insulated... works a treat in mine. then all ya do is turn it on when you want max sound.
  20. #20
    wrx884's Avatar
    Mar 2006
    buy urself a multimeter u can do this urself easily enough as theres plenty of info how 2 do it and im sure the guys will also help u but if ur amps have been installed correctly u should b able 2 put ur DMM on it and see if its pulling any current. if its not then dont bother putting a switch or relay in line its a waste of time and money as it'll b ur regulator that need replacing not the whole alternator.
    generally u can go through 2-3 regulators b4 the alternator packs it in.
  21. #21
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    so u bought a new battrey
    that shouldnt be the problem
    if it is take the ####er back and get a new one
    when your cars running hit your alternator with sumthing solid in a clockwise direction if the engine changes sound bang shes on her way
LinkBacks (?)
  1. 04-08-2011, 06:15 PM
  1. flat battery
    By Petes VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2009, 08:54 PM
  2. problem with battery going flat
    By richie351 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2009, 12:32 AM
  3. flat battery due to extra demand from amps/subs
    By cxcxcxvcvcvc in forum Car Audio
    Last Post: 02-09-2007, 01:51 AM
  4. VS-Battery keeps going flat
    By evanthe mac in forum Electrical Wiring / Questions
    Last Post: 29-09-2005, 09:14 PM
  5. Flat Battery
    By Randy18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:38 PM
