Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By VK SL 3800
Thread: VT V6 Oil light
    07 VE SS
    May 2011
    Default VT V6 Oil light
    When the motor gets warm the oill light comes on i've changed the sender switch is it more than likely the oil pump
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    How many Kms has it done? Could be oil pump, relief/regulator valves or if its mainly at idle its probably excessive main or big end clearance (or both).
    07 VE SS
    May 2011
    thanks for ya comment it's only at idle when in gear and car done 320000 k's
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Its alot of k's, my guess is that its a combination of worn bearings and maybe a worn oil pump. Try using a thicker grade oil, like 20w50 or even higher and see if it fixes the problem for the time being. Long term you will probably end up having to rebuild the engine if its the bearings or overhaul the pump and its control valves depending on what you find when you pull it down.
    07 VE SS
    May 2011
    Thanks heaps for ya replies problem solved i went and bought a VE SS something i been wanting to do for a while
    VT S-Pack S2
    Sep 2010
    lol, cant fix me oil problem, #### it, ill buy a VE SS....
    lol
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Replacing light bulb behind demister / interioir light / dimmer switches
    By seabs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2011, 09:57 AM
  3. Light Tempest Light Metallic Silver Paint Code
    By ruredi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-03-2011, 09:32 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
