Results 1 to 3 of 3
Thread: vx series 2 ls1 intermettint fuel pump issue .
    VX series I I ss
    May 2011
    brisbane
    Default vx series 2 ls1 intermittent fuel pump issue .
    Have a fault with the fuel pump . Have done the diagnostics all relays and fuses are good , did the pump relay overide to find that pump still not working , went to pump/gauge wiring connector at fuel tank disconnected and found 12 volts on the purple and black wires , so no fault in wiring relays or fuses , plug connector back together and fuel pump springs back to life . WTF . Pump has not primed on 2 occassions now .
    Do you think it is the fuel pump or something else like BCM ?
    Last time it did not prime was on a very small angle to the drivers side .
    Anyone have similar problems ?
    If you don`t want to break it , then don`t bring it out to play with it !
    VX series I I ss
    May 2011
    brisbane
    Anybody ?
    Suggestions ?
    vt executive
    Dec 2010
    penrith
    maybe the pump is on its last legs
    $80 for a new pump at auto one
    "I didn't cum on you pete......I swear !"
  1. fuel pump issue?
    By VR_Acclaim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2010, 09:52 PM
  2. fuel pump issue
    By bigdawg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2009, 04:02 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. Fuel Pump issue
    By Ton-Fun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 10:04 AM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
