Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree2Likes
Thread: fe2 suspension
    vt senator
    May 2011
    nelson
    Default fe2 suspension
    Hi all,I have a vt senator and wondering if its possible to make it softer or firmer on the run and store the setting as at the moment I feel every bump in the road(might as well be driving a mini).
    vx executive
    Aug 2010
    perth
    no mate there is no way you can adjust fe2. the only thing you can do is change bushes, springs and shocks. as fe2 on a vt is quite old i would look at something like a monroe gt gas shocks, and keep your springs if you are after a good handeling but smooth drive, which by the sounds of it u are.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Monroe shocks and "good handling"......
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vt senator
    May 2011
    nelson
    Quote Originally Posted by vxcommie View Post
    thanks for that,it handles extremely well even in the wet the way it is at the moment will look at some monroes just to make the ride a bit more pleasant.
    vx executive
    Aug 2010
    perth
    I think they are a good compramise with comfort and sportynes, my mates vx ss has them with fe2 springs. not too fim but not too soft. Feel free to have a good look at other shocks. or even just go for a new set of fe2 from holden
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by cali View Post
    Please don't demean yourself with Monroe's (or pedders for that matter). Go visit site sponsor GSL Rallysport and get yourself a set of KYB's - Excellent value for money shocks that won't ruin your car, nor your self esteem.
    Reaper
    Reapers Black VP SS
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I tried Monroes new GT Sport with my VZ senator Luxury suspension (HSV FE2) and they were too soft on initial bump setting for soft springs and the front would collapse too easily coming off speed bumps.
    The original HSV shocks (Monroe sensatrac) were much better in that regard but out right road holding lacked.
    I now run Koni Yellow adjustable sports stuts/shocks with my original springs and the car handles great.
    The softer springing gives good drive off the mark and the stiffer shocks and bigger sway bars I fitted (whiteline adj 30mm front and 18mm rear) give good handling around corners without sacrificing any ride quality.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    vt senator
    May 2011
    nelson
    Quote Originally Posted by Surfwagon View Post
    I have the standard hsv self leveling suspension with a camber kit fitted so it corners amazing well even in the wet,but the back end seems awfally low as if there is no air in the back shocks at all,is this normal or should there be a gap between the tyre and wheel arch as is on the front?
    vt senator
    May 2011
    nelson
    I have the standard hsv self leveling suspension with a camber kit fitted so it corners amazingly well even in the wet,but the back end seems awfully low as if there is no air in the back shocks at all,is this normal or should there be a gap between the tyre and wheel arch as is on the front?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    vt senator
    May 2011
    nelson
    Quote Originally Posted by Cameron P View Post
    lol are you sure your car hasnt been lowered o.O
    no-I've had a good look under there and it's all bog standard which is what I wanted when I bought it.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    well your guard should sit like 2-3 inches above your wheel shouldnt it? thats the standard fe2 height.. unless the senators are different ?
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    FE2 is about an inch lower then standard (so about equivelant to kings low's). It is possible your shocks are f*cked or your springs are sagging.
    If it isnt tuckin, it must be suckin
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    but whats the go with his hsv self leveling suspension.. would that make it sit lower?
  15. #15
    vt senator
    May 2011
    nelson
    Quote Originally Posted by DM 55 WA View Post
    The car has only done 124000ks I would have thought hsv gear would last a bit longer than that.I should also mention that the last owner who had it for 9 years said it spent most of time sleeping in the garage,I've only had the car for a year-would that affect them?The rear shocks have definately got air lines comming out of them leading to a compressor of some sort bolted just above the diff.The cars owners manual says it is fitted with fe2 luxury sports self leveling suspension but thats about all.
  16. #16
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    the guard shouldnt just sit on the wheel then.. if its bumpy and saggy in the rear end then something is definetely wrong
    brand new range rover sports come into our workshop needing new compressors and other suspension parts so dont think cause its a hsv it wont #### up :P
  17. #17
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    yeah every car is different though mate, its not unlikely that the springs have started to sag, or the self levelling is f*cking up. take it to a suspension shop and see what they say, just dont go to pedders.
  18. #18
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    pretty sure its the same diff as the airrides that pedders do, they sit at level and pump the shocks up when a caravan/boat is towed so it doesnt scrape?
  19. #19
    VX SS
    Jul 2005
    East of Melbourne
  20. #20
    vt senator
    May 2011
    nelson
    Quote Originally Posted by Drewie View Post
    Just a thought, what size rims and what tyre pressures are you running?
    Standard 17x8 at 34 pounds
  21. #21
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
  22. #22
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    i run 38 in my 20s lol, the side wall reckons up to 50psi but f*ck that.
  23. #23
    VX SS
    Jul 2005
    East of Melbourne
    That's what I run in my SS seems a nice compromise between ride and handling, how old are your tyres, I noticed when I put new tyres on my SS the ride was a lot softer.
  24. #24
    ve sv6
    Aug 2010
    the factory self leveling suspension is monroe air shocks that work off a compressor and a sensor that is mounted on the rear x-member just off centre on the rhs and has a little arm that mounts on the trailing arm that switches on the compressor when needed. the shock are what holds the car up to the correct ride height not the coils. the coils are what is called a half rate coil meaning its not the same as a standard coil, they wont work if the shocks dont work. is the car always at the same height or does it pump up after you drive it for a bit? when you switch the car on do you hear the compressor kick in?. the airbags on the shocks might have a hole in them so it doesnt keep the pressure or the compressor has sh1t it self, common problems for both. if its just the shocks you can change them with aftermarket monroes or genuine holden ones. if its the compressor you cant buy them new any more and its hard to find a second hand one that is working. best option is to get a new set of coils either aftermarket or genuine gm non self leveling fe2 coils and a new pair of non self leveling shocks.
  25. #25
    VZ AWD One Tonner
    Jul 2006
    As Reaper said a set of KYB's will go along way to making it better ($145 each for the front, $69 each for the rear) and are a decent step up from Monroe (Tenecco).
    But if you want the ability to change the dampening of the shock, you either need to get something like Koni Yellows ($275 each fro the front, $209 each for the rear), or a quality coilover like DMS 40mm, which is $3508 per car set including springs, freight and GST.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. Sedan Suspension to wagon suspension
    By BADNWS in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2011, 05:01 PM
  2. FE2 suspension
    By donboy2000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2010, 07:39 PM
  3. Suspension on a Vt
    By VTmadS1 in forum General
    Last Post: 30-10-2009, 08:12 PM
  4. vt,vx,vy suspension
    By spikeu in forum General
    Last Post: 27-09-2009, 11:29 PM
  5. vk suspension
    By iceroffey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-09-2007, 10:17 PM
