Results 1 to 2 of 2
Thread: Vx v6 sump removal
    VHSLE/VXSS/VXEXEC
    May 2011
    Default Vx v6 sump removal
    Hi guys went out today and moved the wifes VX and noticed a pool of oil under it....I had a look underneath and it looks like its coming from the sump gasket but hard to tell as it seems to be leaking behind the harmonic balancer...i cleaned the area and i nipped up the sump bolts at the front a bit more took it for a drive and it still leaked so i nipped them up a tad more i took the engine back up to working temp again and drove it a few klms it seems ok now but Im still not 100% sure if ive fixed it...ok the question Ive read a few things and it looks like you dont have to take the engine out you just have to raise the motor up...is this true? any info on doing the job would be helpful...also behind the harmonic balancer and between the timing case there seems to be a plastic cover thats just sits there any one know what this is?...im probably not describing that part well but help on removing the sump would be great. cheers
    the good thing about getting older....more toysthe bad news more headaches
    scvs6's Avatar
    scvs6 is online now Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    It could just be the front engine seal. Check that before you change the sump gasket.
    At work, usually we pull the engine out of the car and change the sump gasket and rear main seal at the same time. You can also drop the cross member but you need something to support the engine because the engine mounts will have to be undone.
    Sump gaskets seem to be common to leak on commodore V6's, I have done a few at work.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
  1. Vp Sump Removal
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2010, 12:38 PM
  2. VP V8 Sump removal hrmmm
    By PaRaDoX in forum V8 Development and Modification
    Last Post: 18-02-2008, 08:24 AM
  3. V8 oil sump removal
    By cit51 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2007, 08:03 PM
  4. vs v6 sump gasket removal
    By 308commodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2007, 07:30 PM
  5. Sump removal
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2006, 10:56 PM
