Results 1 to 17 of 17
Thread: Random Stall/shudder on idle
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Default Random Stall/shudder on idle
    Been happening for a few weeks now. Stalled 3 times within 1 hour. then nothing for a week. then started shuttering and a few random stalls in between. Does it mostly when the motor is warmed up. ONLY ever on idle. so sitting at traffic lights, it will shudder, revs drop riiiiight down then it will pick itself up and go back to normal, other times it wont recover and just stall.
    Leads/plugs were replaced 8 months~ ago. fuel filter/air filter/ oil filter/oil all replaced last service (6 months or so ago)
    i so far have a list of the cause being from
    EGR valve?
    A faulty coil pack
    Dodgy fuel? even tho i get it from different places
    Im stumped on this one, any help is much appreciated.
    som
    som is online now
    vt executive
    Apr 2011
    thorneside qld
    possible throttle position sensor which would show on a diagnostic check (as may other possible cause of your problem) Anyway if it is a tps they're cheap and simple to replace.I reckon I'd go the diagnostic check first.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    +1 for throttle position sensor.
    if it was dodgy fuel it would miss whilst driving right
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by Cameron P View Post
    this is correct
    If it isnt tuckin, it must be suckin
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by DM 55 WA View Post
    this is correct
    i wasnt asking i was telling hahaha
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    googling around a few people mention the Crank Angle Sensor can play up when hot? not sure on that either
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    there common so you might aswell start there and even if it doesnt fix the issue it will save you hassle in the future
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    Ok just went outside and did a diagnostic test on it. i got the codes
    12 - Satisfactory Operation
    46 - Crank Angle reference signal (engine will not start)
    47 - Crank angle reference signal (no signal)
    Then it started repeating again as it does.
    SO i believe im now off to bursons to get a CAS
    vs commodore
    Oct 2009
    Tamworth NSW
    Id definitely be replacing the CAS.Id try to get a genuine holden CAS if you can,they may be more expensive ,but they seem to last a lot longer.Ive seen plently of the cheaper ones fail just a couple of years later or even less,so it can work out more expensive in the long run if you get a dodgey one that only lasts a couple of years..
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    I bought a new CAS and a harmonic balancer puller kit. Just have to work out how to get the main nut off first. Im thinking sit a long breaker bar on the nut and againts the chassis and crank the motor real quick to break the seal
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    why not use some muscle lol. your idea is a little crazy im my opinion o.O
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    yeh you could try it that way, do you have a rattle gun? if u want to do it that way id check to see if the motor is going to spin way to undo the nut with where u have placed the breaker bar otherwise snapp bolt. also take the fuel pump fuse out and make sure the engine wont start on you.
    i had a similar problem in my vt ss with the shudder/stalling when i pulled up turned out faulty earth lead engine to chassis and faulty battery and alternator.
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    Nah i should be good with earthing, im a full time audio installer. 2 runs of 1/0 gauge wire to the Alt/batt/chassis and the positive on the Alt lol
    Dec 2008
    Perth, NOR
    the wires are good n all but have u checked the resistance between all of these.
  15. #15
    99 VT Acclaim Wgn V6 Auto
    Jan 2007
    Hey sxc_sound
    Did changing the CAS fix your situation? I am having exactly the same problem atm. I had a CAS go on my old VP but with that the car would just die all the time, my VT is running great EXCEPT at the lights with the auto in DRIVE its starts going a bit silly. If it starts doing it while I'm driving or dying then yeah, it could be the CAS. Nothing a squirt of water wont fix.....albeit temporarily.
  16. #16
    VT S-Pack S2
    Sep 2010
    I had the same prob, i replaced the CAS and cam angle sensor... never had a problem since
  17. #17
    Jan 2007
    Hey sus_038
    Hmm, seems like maybe my CAS is dying. I know where they are on a VP but whereabouts is it in the Ecotec engine? Somewhere near the HB I gather but right side/left side of the HB??
  1. VS Gas stall at 60-90km Idle
    By Tadz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2011, 10:02 PM
  2. random idle, stalling problems
    By vn_v6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-11-2010, 07:04 PM
  3. driving / random stall / sumtimes just cranks when starting
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2008, 08:52 PM
  4. Random stalling at idle
    By Nobody Actually in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 10:06 PM
  5. Poor idle then stall
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 06:31 PM
