Results 1 to 3 of 3
Thread: Bottom ball Joint
    VX 02 - CBR_RR_Pulsar Et Turbo_4AGZE Corolla
    Jun 2011
    Brisbane/QLD
    Default Bottom ball Joint
    Hey guys wondering how too get the ball joint arm or wateva it's called off the brake hub off the front right hand side as i'm changing the whole thing due too the bearing on my my VX Commodore..
    The problem it, the thread is spinning with the nut so I can't undo the nut...
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    yeah... thats a locating ball joint on a macpherson strut setup, so it will spin after 14-25nm of force is applied(by spec of manufacturer)....
    use a pry bar (lever bar) to force the control arm downwards at the front pivot (near k-frame) onto the arm half way along
    so that it takes more than 25nm of force to make it spin..... and wd40 or similar too left for an hour will help alot i have found....
  1. ball joint?
    By TWOJZ in forum General
    Last Post: 25-06-2008, 09:11 PM
  2. Replies: 16
    Last Post: 03-03-2008, 12:31 PM
  3. Lower ball joint!
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2007, 11:54 PM
  4. Ball joint removal
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2007, 07:52 PM
  5. Lower Ball Joint VP
    By PaulW in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 06:53 PM
