Results 1 to 5 of 5
Thread: severe vt v6 oil leak!!
    09 VE Clubsport R8 317/ VT Commodore exec 5 SPD
    Jul 2010
    melb
    Default severe vt v6 oil leak!!
    hey guys driving home 2nite, all of a sudden i could smell melting tar/plastic in the cabin n within another 5 mins my oil signal in the cluster kept flashing on/off, i drove home really slowly n as i stopped the car, there was a trail of oil in the path id jus driven. quickly jacked up the car n the whole undercarriage was covered in oil (no oil in reserve either). i didnt know where to start. i degreased it then hosed in down, i think its coming from the oil pressure sender near the oil filter. is it possible for oil to leak from there?? ive been under the car for the past hour n jus want an answer. any type of help would be awesome!!
    vz wagon
    Aug 2006
    Wild west of Melb
    Yes it is possible as the sender has to have oil there to send the signal if its got oil pressure the best way to check if ya cant tell by just lookin at it would be to put some more oil in it and turn it over to see if it pumps oil out the front. but have some one turn it over so if it does start they can shut it off as ya dont really want it runnin as if it is pumping the oil straight out the front it wont be getting much through the engine.
    Jul 2010
    melb
    Jul 2010
    melb
    yep it was the pressure sender, it spurts out from between the wired connector and the body of the sender. do i just hav to replace the part thats screwed onto the block? or do i replace the whole wired part too?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    You buy a new switch. Just unplug the connector lead off the nackered unit, screw in the new one, and re-fit the connector!...Simple. Wouldn't hurt to put a smear of thread sealer on new sender before screwing it in. Don't over tighten it either as it has a tapered thread and is vertially self sealing.
  1. vs clubsport 5 litre sudden severe rear oil leak
    By clubsport999 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2010, 09:26 AM
  2. Severe Headaches
    By Deutscher in forum Jokes/Humour
    Last Post: 03-07-2008, 07:36 PM
  3. Factory Manual ??? And Severe Leak
    By benno145 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2008, 09:36 PM
  4. severe shudder
    By ireland in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2005, 02:20 PM
