Results 1 to 16 of 16
Thread: VT Rear Demister
    GSXR1000
    Apr 2010
    WA
    Default VT Rear Demister
    Hey guys,
    Looks for a few pointers as I'm planning to have a look to see if I can fix my demisters.
    Currently when I push the demister button, I can hear a click under the dash. Fuse seems to be fine, I'm not sure about the larger fuse/relay thing though. The demister wont work at all, so I'm just trying to find out where to start looking, thought the 'click' might be a clue as to what's wrong.
    I think the rear window has been popped before as I've found bits of glass throughout the boot when cleaning it out.
    Could the connectors not have been wired up again potentially?
    And where are they located on the VT's so I know where to start lookin?
    Cheers!
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    yeh sounds like the havent been conected, if u remove the c pillars (trim panel the rear seatbelts go through) you will see two connectors on the d/s one comes from the body loom p/s one is a short lead that earths to the body.
    hope this helps
    GSXR1000
    Apr 2010
    WA
    Cheers mate, fingers crossed this is all it is :P Will be nice to have it working again haha.
    Do the back seats need to come out at all or do the pillar trims just pull off ?
    som
    som is online now
    vt executive
    Apr 2011
    thorneside qld
    big chance it's a relay which is on your fuse panel below the steering wheel.the fan relay is the same and they sit alongside one another so you can temporarily swap them to check. may take you all of a minute.good luck.
    GSXR1000
    Apr 2010
    WA
    Dec 2008
    Perth, NOR
    yeah will prob need to take the left and right seat section out as there is a trim screw in the bottom on the pillar trim undo the grab handle and it will just unclip.
    but yeh do the relay swap first i thought i read that you already tried that..
    GSXR1000
    Apr 2010
    WA
    Nar checked only the fuse, didn't think to swap over the relays to see if the one I've got in there was borked.
    GSXR1000
    Apr 2010
    WA
    Well tried the relay thing (spent ages trying to jam them in once I got them out cause I had them the wrong way out... fkn idiot....*face palm*)
    Didn't seem to do anything, was able to pull the trims back enough that I could have a good look behind. Looks like the passenger side isn't connected at all.. there isn't even a prong from the window to connect it to ffs.
    Would a windscreen place deal with this sort of shit ? could they solder something on to the strips ? or is it a job for a sparky or someone else?
    I swear, everything that the guys before me touched on this car... they've ####ed and now I have to fix it.
    The only result I got out of today was removing a stupid Nokia speaker for a hands free device that was once installed...
    Dec 2008
    Perth, NOR
    they are a fair way back from the trim were u able to see the metal section of the pillar
    GSXR1000
    Apr 2010
    WA
    Yeah could see the wiring etc fine, could see that it's earthed to the pillar, but on the drivers side you can see the metal prong the cable connects to on the window, on the passenger side, there's nothing for the earth wire to connect to...
    Dec 2008
    Perth, NOR
    you can buy a repair kit dynagrip product
    DynaGrip® Rear Demister Repair Kit comes complete to repair either broken grid lines or loose connector tabs.
    Repairs broken grid lines.
    Reattaches loose connector tabs.
    Silver filled epoxy.
    Permanent repair.
    Demister can be used in 30 minutes.
    GSXR1000
    Apr 2010
    WA
    might have to have a look for this, thanks!
    Will probably need to be a connector tab too cause mines obviously missing, and the kit, from what I can see by the pic at least, doesn't seem to come with more tabs.
    Dec 2008
    Perth, NOR
    yeh dont think they do i got a rear screen here u can have the tabs off if u want them.
    Dec 2008
    Perth, NOR
  15. #15
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    have u got urself a test light yet daniel? if not get 1 and put it on those connectors on the back window and see if u got power there
    Can u see a metal contact area on the back window where there should b a tab on the drivers side just like the passengers? u could solder a tab in place if its missing.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  16. #16
    GSXR1000
    Apr 2010
    WA
    Haha no test light yet... I always forget when I'm in an auto store :P
    Thought I could see a metal contact area but not too sure, will have to double check.
    Bill, you're a legend dude, might be keen, will have another look at this window to be sure there's metal I can solder onto.
    Let ya know man, cheers!
    Nope... no metal contact area... looks like there used to be something there (there's a gloss on that area of the window), but no metal..
    fail.
  1. rear demister
    By calay in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-06-2010, 04:09 PM
  2. Rear demister cause rear window to shatter?
    By gendi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2009, 10:24 AM
  3. vn rear demister
    By grothie1978 in forum Electrical Wiring / Questions
    Last Post: 14-02-2008, 05:33 PM
  4. rear demister
    By mws in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2007, 06:21 PM
  5. rear demister
    By stock_vl in forum Electrical Wiring / Questions
    Last Post: 19-08-2005, 10:37 PM
