Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By accentstencil
Thread: How do you replace bulbs in temp + fan switchs in the centre for VX
    Holden Commodore VX 2002
    Jun 2011
    Default How do you replace bulbs in temp + fan switchs in the centre for VX
    Hi im new to the Holdens and enjoying every moment of it, ive recently brought a VX ss with a few porformance modifications.I was wondering if any one could help me.?
    Im having trouble finding how to replace to bulbs behind the fan+temp switchs.
    I have looked all through gregorys and searched on this site but cant seem to find out how, its quite annoying at night as you could imagine.
    I have tried just taking the nobs off and priying the unit off witha butter nife wraped in cloth to prevent scrathing but doesent seem to want to budge. I dont want to give to much force just in case its not the way to take it off.
    Any advise will be apreciated.
    Ben
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    This should help, it is by courtesy of Spyper. Unfortunately the thread is that old that the links to the pics are no longer working.
    Ok if you're just going to be replacing globes, the job will be easy enough. The hard part is taking the white backing (that the globes and controls fit to) off, because you need to disconnect plugs and gears.
    Ok, as for taking apart the AC controls.. easy job.
    Disconnect the battery (negative terminal will do).
    Take off the dash starting by removing the CD player (Edit: This does not need to be done - sorry). This is done by inserting cut/bent coathanger into the 4 holes, 2 on either side, then pulling the cd player out.
    http://members.optusnet.com.au/skylo...h/removecd.JPG
    Undo 2 screws, 1 either side of the lighter socket, underneath the compartment/ashtray. Then lift up the plastic surround of the gear stick. There are a few clips that hold it in, use a flatblade screw driver to lever them out a little. MUCH easier with two people.
    http://members.optusnet.com.au/skylo.../removecnt.JPG
    http://members.optusnet.com.au/skylo...cntremoved.JPG
    Not sure if the compartment needs removing, but this is how.
    http://members.optusnet.com.au/skylo...ompartment.JPG
    Take 2 screws out at the top of the cluster.
    http://members.optusnet.com.au/skylo.../dash/dash.JPG
    Flip down the fuse panel directly under the steering wheel, its held in by a few clips. Undo the 2 screws on the right, and 1 screw on the left.
    http://members.optusnet.com.au/skylo...fusepanel1.JPG
    http://members.optusnet.com.au/skylo...fusepanel2.JPG
    The dash should pull out from there, but there are a few cables connecting it, so disconnect the cables.
    http://members.optusnet.com.au/skylo...h/dashface.JPG
    To take apart the AC controls, pull the dials/switches off the face. You may also need to undo one screw each side.. I forget.
    http://members.optusnet.com.au/skylout1169/dash/ac.JPG
    http://members.optusnet.com.au/skylo...h/removeac.JPG
    Just unscrew the globe holders, they twist half a turn from the back. Screw the new ones in. Reverse the procedure to put it all back together. If you need anything else, just ask =)
    MY RIDE
    VU S2
    Jan 2011
    Cool
    Quote Originally Posted by accentstencil View Post
    Decent write up, I just replaced all of mine last week, wish I knew of this.
    Whilst you're in there, I'd suggest replacing all dash globes where the speedo is also, you'll notice the difference, saves you having to do it again & the globes are the cheaper of the lot!
    Jun 2011
    Default Bulbs
    Thanks so much i will do this soon,apreciate you taking the time in replying!!
    I dont surpose you know the bulb sizes for the heater controls ?? and are the spedo bulbs the same to?
    VU S2
    Jan 2011
    Quote Originally Posted by beny87 View Post
    Sorry mate, can't remember size but the ones behind the dash clip in and out easily, it's the ones behind the heater controls that you need to buy the globe which comes in a screw in retainer, they're about $11 each from Holden.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    depends on which heater unit u have? there r 3 different standard type heater controls funny enough that each all use different size globes.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by wrx884 View Post
    I have to replace some of mine too .What do you mean by three different types ? I though there was only the standard type or the climate control type.
    wrx884's Avatar
    Mar 2006
    Theres 3 types, its all 2 do with the internals and the PCB's and how they r layed out, yet all 3 work the same and look the same, but the globes in each PCB r different in size.
    Best way 2 match them up is 2 take out the globes from behind ur own A/C and demister buttons as most of the others u cant access unless u strip the unit right down.
    boomnvn's Avatar
    boomnvn is offline SOLDER, NO CRIMP.
    VT Exec S1 V6
    Oct 2006
    Croydon
    I can make up a ciruit board with any colour LED on an exhange basis if you like as well, just mount in your existing aircon/heater control unit...
    PM me for pics and prices
    Cheers,
    Liam.
    CAR: VT Commodore Sedan audio car - SOURCE: 7" double DIN DVD/GPS - AMP: Pioneer monoblock / Pioneer 4 ch. - SUB: Kenwood DB+ 12" in 22lt slot ported box - REARS: Kicker RS60.2 splits - FRONTS: Kenwood KFC-S702P splits - MISC: Custom fiberglass iPhone4 dock moulded in center console, White / red LED cluster and dash lighting, SAAS Vortex drivers seat
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by boomnvn View Post
    Cheers,
    Liam.
    Only the 3rd type needs a custom PCB board made up, which r usually found in the SS models that werent optioned with climate control ive found.
    The other 2 u use the existing boards.
    boomnvn's Avatar
    VT Exec S1 V6
    Oct 2006
    Croydon
    my point was that, doesn't matter what type of HVAC/Climate control he has, I can supply a board to suit with any colour LED directly soldered on so it's just a case of swapping the boards over.
    make sense?
    wrx884's Avatar
    Mar 2006
    make sense?
    yep we do the exact same thing man
    boomnvn's Avatar
    VT Exec S1 V6
    Oct 2006
    Croydon
    Yeah cool mate, where do you work?
    wrx884's Avatar
    Mar 2006
    ASR check the sponsor up top on the main page, im in perth and Greg is in sydney.
  15. #15
    boomnvn's Avatar
    VT Exec S1 V6
    Oct 2006
    Croydon
    cool mate, I'm from kung fu kustoms in melb.
  1. replace gear indicator lights in centre console?
    By som in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2011, 04:31 PM
  2. green bulbs under driver side, passenger dash and centre console/rear bulbs
    By GMHCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2009, 01:12 PM
  3. How to replace headlight bulbs
    By akqrate in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-05-2009, 11:53 AM
  4. Lamps in VR dash (temp & fuel) gauges blown.Any ideas on how to replace them, thanks?
    By Buflina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2007, 10:47 PM
  5. power window switchs
    By kyl'svs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 10:41 AM
