Results 1 to 6 of 6
Thread: soo wierd!!
    series 2 vt wagon
    May 2011
    newcastle
    Default soo wierd!!
    my vt when started is runnin fine, but once it heats up and the thermos are supposed to kick it they dont and the car stalls! weve had the car on diagnostics and turned the thermos on manually and it runs fine, but without it labours to all buggery! suggestions anyone?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Replace the thermostat.
    Check the water level...
    Do a cooling system flush.
    There is no such thing as stupid questions, Only stupid people.
    VHSLE/VXSS/VXEXEC
    May 2011
    if you work out the problem let me know my vx 5.7 was doing exactly the same thing although it hasnt for ages but i would still like to know
    the good thing about getting older....more toysthe bad news more headaches
    series 2 vt wagon
    May 2011
    newcastle
    yeah no worries... ive been looking all over the net and the only thing that keeps comin up is the electrical side if things mainly bein relay and faulty sensors... only problem is im unsure of where the temp sensor is on the ecotecs... little help?
    vs commodore
    Oct 2009
    Tamworth NSW
    I had a problem with my VS where the cooling fans would not cut in,I looked for ages trying to track down the problem,replacing relays and testing wires etc,It ended up being the ECU had half died and wasnt commanding the cooling fans on,so if you tried everything else, and have had no success,then keep the ECU in mind.Its probably not that,but you never knoiw.It certainly had me stuffed,it was the last place I thought the problem would lie...There was no other problems with the ECU,just the cooling fan side of things..
    series 2 vt wagon
    May 2011
    newcastle
    hmm i might give it a look into, im absolutely stuffed tryin to work out whats goin on tho...
  1. wierd noise PLEASE HELP!!!!!!!!!!
    By fatbt1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2011, 04:28 PM
  2. VX gen 3 wierd problems.
    By mrgem1982 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2011, 09:26 AM
  3. alloytec maf wierd?...
    By Dz811 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-11-2010, 08:14 AM
  4. wierd ve problem
    By programer in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 06:59 PM
  5. Wierd vibrations
    By ragrim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2007, 03:13 PM
