Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: URGENT HELP- cant get wheel nut off
    1994 Hilux V6
    Sep 2010
    Newcastle
    Default URGENT HELP- cant get wheel nut off
    long story short, i cant crack this nut, after swinging a breaker bar off it and rounding it, i tried the hammer and chisel. now the nut is completely f**ked ( i have spares).
    what u guys reckon?
    i thought take the whole front wheel off from behind. can u take the disc brake off the wheel from behind? either that or take it to somewhere with a oxy and burn the stud and nut out
    please help!!!
    91 vn s
    Jun 2009
    Adelaide, SA
    nope just grind some flats into the rounded nut and try and get in there with an adjustable spanner or wrench. oxy would be (quite) advantageous
    1994 Hilux V6
    Sep 2010
    Newcastle
    there isnt a nut anymore, ive been trying to chisel it off now, not goin to well but it is getting there. cant really get a grinder in there anyway, the nuts sit into the rim a bit
    Rob_VT's Avatar
    Rob_VT is offline Smacked Up
    VT SII
    Jan 2010
    Warilla, NSW
    is it a stocky? or a rim?
    if its a stocky, oxy on the nut and heat it, then spray something like plusgas or wd40 onto it (use alot)
    then heat again and spray again.
    do this a couple of times.
    then get a smaller socket, impact socket if u have one, bout 2mm smaller and bash it on with a hammer.
    then try the breaker bar with a hydraulic jack as leverage.
    good luck mate
    1994 Hilux V6
    Sep 2010
    Newcastle
    its a VT ss rim. half the nut has been chiseled away so there is no way of putting any sort of socket on. might have a go with the drill and drill a few holes in the nut close to the stud and try to crack the nut in half. most likely have done a bit of thread damage to the stud. they not that expensive are they?
    VT Calais
    Mar 2009
    SA - Victor Harbor
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Drilling a hole in the nut next to the stud and split with cold a chisel is the way to go!
    series 2 vt wagon
    May 2011
    newcastle
    yeah i agreee with pablo... drill a few holes into the nut then use some form of heat on it then give it a smack with the chisel again... make sure youve got safety glasses on tho... it should split the nut in half. and to answer the other question the bolts are about 2 bucks each depending where you go!
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    1994 Hilux V6
    Sep 2010
    Newcastle
    heres a picture. think im just gonna take it to a mechanic tomorrow. atleast they would have some sorta clue and proper shit to get it off. such a simple thing that turns into a massive headache
    1994 Hilux V6
    Sep 2010
    Newcastle
    oh and pretty sure rim is ####ed as well with all the banging and shit like that, so its stockies til i get another one
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    holy shit thats crazy lol
    as to getting it off geez have fun i reckon possibly oxy is the only way. maybe get a really big drill bit and drill it out like u would with a pop rivet then just replace the stud which is easy / cheap to do. . . . the wheel should be ok though
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Well judging from the pic the nut has bitten into the rim and jammed itself.... and the actual stud looks like is bent as well...
    A drill is going to be your answer, take it slow, use a brand new drill bit & oil.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
  15. #15
    VX SS
    Jul 2005
    East of Melbourne
    I think I would drill a series of small diameter holes in a straight line working out from the stud towards the outer edge of the nut, use a sharp centre punch to give the drill a nice start, hopefully once you have drilled say maybe 3 or 4 small holes you may be able to use a small chisel or screwdriver to split the bits between the holes you have drilled and split the nut and reduce the tension. Worth a try, bugger of a job which ever way you go, use a brand new quality drill bit and a sharp centre punch to start the drill. Good luck with it. As an after thought maybe put the other nuts on and do them up pretty tight while you work on ithe damaged one as they may take a bit of pressure off the buggered nut.
  16. #16
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
  17. #17
    1994 Hilux V6
    Sep 2010
    Newcastle
    thanks for all the inputs.
    just gonna take it to the mechanics today though, save me wrecking it more.
    it all started cause i couldnt get it off, i only have double hex sockets ( lost my wheel brace) and so it stripped, then tried hammer and chisel and that is whats left.
  18. #18
    VX Executive S2
    May 2006
    Frankston South Vic
    get a larger nut preferably id is same as your od ,that you have a socket for and get someone to weld new nut to old nut
  19. #19
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by kid_720datto View Post
    Click image for larger version.
    In the words of Vinny:
    ...Tyrone, what've you done?
    Bit late for taking it to the mechanic at this point wouldn't you say?
    I imagine that at best you're going to need a new stud and at works a new stud and rim.
    I guess form this you can take away that if you have a really stubborn nut in the future, take it to a mechanic or tyre place for them to try and remove it with an impact wrench.
  20. #20
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    INSTA FAIL
    The hubs usually rust to the rim mounting face and the wheel nuts can also rust on...what you should have tried is some WD40 or lubricant before swinging too hard with the breaker bar...You can usually tell when a bolt is not budging and further force will break it.
    If you burn the nut out your most likely to damage your rim...
    No suggestions, you've ####ed that thing good and proper like a St. Kilda hooker.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  21. #21
    vs commodore
    Oct 2009
    Tamworth NSW
    If the rim is not a real good one,you could try loosening the other 4 wheel nuts,and then try driving around in a circle with that wheel on the outside to load up that particular wheel,this might load it up enough to snap the rest of the broken nut off, or it might even snap the stud,either one will do,and the stud will need replacing anyway,so that doesnt matter.And it wont hurt the car as the other 4 wheel nuts will hold the wheel on,you just need to have them loosened a few turns,say half way, so the rim has room to move sideways ,but not come off completely.Obviously I dont have to remind you to do this on private property so no one can get hurt..
  22. #22
    Zarconia's Avatar
    Zarconia is offline Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    I had the headache of one of the nuts on the thermostat snapping off, tried that ez crap, dont recommend it. Spend a good week pissing around trying to get the thing out. My advice. Stop right now.
    Get someone with an oxy, weld a new nut on it then unscrew the new nut. Will take a few goes with the oxy but it will get it off in the end.
    The rim by looks of it is going to be stuffed, but its your only option.
  23. #23
    VT
    Feb 2010
    By the look of that photo, The easiest way without wrecking the rim will be to drill the stud out.
    Start with a 2mm drill bit for a pilot hole and plenty oil to keep the drill bit cool,(You don't need to drill it all the way, Just enough to get passed the wheel nut)
    Then move to a drill bit around the same size as the wheel stud (use a slow drill speed)
  24. #24
    1994 Hilux V6
    Sep 2010
    Newcastle
    thanks DRAGON and Zarconia, i got it back from the mechanics for 88 bucks. he sed i had done a pretty good job chewing around the nut. thats exactly wat he done, drilled the stud out to the rim, pulled the rim off, replaced the stud and wheel nut. happy days. rim is stil ok, just a few gouge marks from the chisel but im not that fused, ill replace them with a clean set of 19's or somethin later on.
    definitely taking it straight to a shop next time i cant get one of them off at home with a brace or breaker bar.
    thanks again for all the inputs
  25. #25
    May 2006
    Give your self a bit of an easier time by putting a smear of grease on the stud thread before you tighten the nut to 75 ft. lbs tension. (around 102 N.m. from memory)
    OH!...and always use the correct size wrench.
  1. Urgent- VS steering wheel stereo control problems.
    By lethal SENATOR 185i in forum Car Audio
    Last Post: 23-03-2010, 05:47 PM
  2. URGENT - Steering Wheel Troubles!
    By jozza87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2009, 09:27 PM
  3. VT Rear Wheel Hub Urgent
    By davidbmillar in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 02:51 PM
  4. URGENT- vr fly wheel asap
    By winton in forum Swap / Wanted to Buy / Trade
    Last Post: 19-09-2007, 12:26 AM
  5. URGENT: Removing VN Steering Wheel?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2007, 02:58 PM
