Results 1 to 3 of 3
Thread: topping up coolant
    vt
    Jun 2011
    perth
    Default topping up coolant
    hey, ive got a vt commodore and was going to flush the coolant out and change then half way through realised you need flushing kits etc. so not going to bother doing that and already pulled the bottm radiator hose off to drain coolant. i only lost about 1.5l. with hoses back on do i top up the coolant straight into the radiator to top? just seemed to be putting way more than 1.5l in this time? over flow is full also? help
    thanks
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Ensure the car is on flat ground and is cold. Open the radiator and pour the fluid into it... Start the car with the radiator cap off and the water pump should start to take the water through the block, top it up again... Put the cap back on. Be careful you dont get an airlock in the radiator hose.. You can squeeze them to feel if its got air or water in it.
    vt
    Jun 2011
    perth
    All to easy! Thanks mate.
  1. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  2. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  3. Low level coolant light staying on, even though coolant has been topped up
    By luckyluciano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2010, 08:40 AM
  4. Is this the right coolant???
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2008, 06:19 PM
  5. Topping up Engine oil????
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2006, 11:22 AM
