Results 1 to 7 of 7
Thread: ls1 sump gasket
    VT SS 5.7
    Mar 2005
    Goulburn
    Default ls1 sump gasket
    How hard is it to change the sump gasket on my vt ls1 6spd?
    if its to much of a pain i nthe arse i might try and get a mechanic to do the job (bye bye cash)
    Real cars don't power the front wheels, they lift them
    Boonz's Avatar
    Boonz is offline Donating Member
    green 355 VG ute
    Jul 2005
    berri, south australia
    got 2 jack stands,a trolley jack and engine support bar??? you can undo the crossmember and take it off, of remove the gearbox and tilt the engine forwards enough to clear the pickup
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    A mate of mine did the same as above, he dropped the steering rack,put the stands under the body took the wheels off and let the k-frame hang there will holding the engine up with a crane and there was enough room. Prick of a job but doable.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    this sucks, i have dropped the oil pump pick up bolt in the sump when i was changing the timing chain over! i have drained the oil but am now going to buy a pen magnet to see if i can get it. otherwise its pulling the sump off
    VT SS 5.7
    Mar 2005
    Goulburn
    Quote Originally Posted by johnno010684 View Post
    Sorry mate but i do not envy you
    Sep 2008
    Auburn
    ok so i bought the pen magnet but i still cant find the bolt, guess its holding the engine up with a jack and pull the sump off!
  1. Vl sump gasket
    By myvlv8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2011, 11:15 AM
  2. Sump gasket
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2010, 12:36 AM
  3. vt sump gasket
    By tumut123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2010, 08:26 PM
  4. vr sump gasket
    By jasonvr93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 06:30 PM
  5. Sump Gasket
    By sunriseoversea in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2005, 04:52 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
